OCUK Sandy Bridge, SB-E and Ivy Bridge 5GHZ Club
Who says the latest batch of 2700K's dont clock well!!!
Got this for a custom project as Ivy will not go as high without Xtreme cold (-100). I was surprised at how well it did. The memory controller was very bad though no 1T above about 2000mhz sadly!! You cant win em all!!
This is on -45 Single stage.
Soz bud!!!
I think I will start a new thread then, thanks for the suggestion!!!! This one is Prime stable at 5.8 HT enabled!!!! LOL!!
Wazz_1 its LN2 cooling!!! big minus numbers allow this.
TD nice one!!!!
I have a new Ivy from Slamms that does 6.9 for 1mb on LN2. Samebatch as his 7ghz+ chip.
Where did you get that background from??? I like it. Just needs abs!!!
dam it, got about 50hz off, could boot into windows.... just but then crashes but i dare not push voltages further, 1.595 is max for me, tried different multi's and Bclk, nearly booted with a 106 bclk, ah well think i need to read and learn more, still new to this, one day i will make this club!!!:rolleyes:
are you guys using a stripped down windows for this???
just noticed i have a missing driver now.
Can I join the club
Do i7 have a higher threshold for vcore, what are there stock vids?
I am under water, couldn't up the volts any more, I was literaly depositing bricks on my computer chair. I set my self to buy a new cpu should anything go wrong :D couldn't go higher on them volts and didn't want to use any more.
I can do 5GHZ at 1.4 I think it was, maybe a shade lower but 24/7 it seemed too high.
Nice clocks BTW
I do not run the xmp, any benefit?
