** OCUK TECH LABS AIO LIQUID COOLERS - PRICE SLASH **
I'm looking and buying the OcUK Tech Labs 240mm+ Extreme CPU Liquid Cooling Upgrade Bundle, but can anyone (OcUK) confirm if the bundle comes with the 8 longer screws required for mounting the rad?
I ordered the 240mm this week - mine came with 8 longer screws...
I't a good bit of kit, I'm really pleased with it :)
They have been out of stock (240mm+) for a couple of months. I got one with the Kraken G10, it came with 2 sets of screws IIRC the longer ones were the only suitable screws.
Well got this strapped to my extreme edition chip and it never goes over 69 degrees when benching, really impressed as its quiet as well..
Anyone else running a 360?
Have one here sitting next to me, havent fitted it yet as I'm waiting on a tube of CLU to come, delliding on Christmas day :D Might do a before and after test actually.
I noticed there's no instructions, do you have any or is it fairly straight forward?
No instructions with mine either mate, I just worked it out, ive fitted a few of my own and for friends, just have a play before you get round to it for real...
Are you using the grizzly?
Its worth doing the test, its the best cooler I have ever owned.
its pretty much straight forward.
if you google about for fitting instructions for any aio cooler, they are all the same in principle.
Yup I've a tube of grizzly for between the cooler and IHS, CLU for between die and IHS :)
You using the fans that came with it ?
Yep i'm using the included fans, they are decent in terms of air movement but could be a little quieter, as you need 3 I am holding off replacing them till I have a bit of cash burning a hole in the pocket.. Certainly good enough to get you started though.
I'll have a play around with fans, I've about 8 SP120s in a box here somewhere
So rjk should i get the OCuK Tech Labs 360mm AIO or the wait for the new Corsair H110i V2 that are soon to be in stock? In terms of performance(Temps) and noise.
Thanks
360 will smash the corsair in terms of performance. noise is down to you really as our fans perform well but work best when paired with a fan controller :)
Thanks for the reply!
Yea thats what I was thinking. I was going to invest in three different fans or perhaps keep the stock ones but get a fan controller to control the speeds. I was thinking stock fans running at 50% would still perform better than the corsair h110i v2.
How is the pump noise on the ocuk 360 AIO?
