Because many games still only use 2 'main' threads, no good having 8 average cores that are amazing with 8 threads when only 2 are really being used.
In that situation it's more down to per core efficiency, which BD lacks.
Assuming equal pricing why would you not want the CPU which will have more space to let more powerful GPUs shine?
If all you want is an adequate CPU to play games why are you interested in BD _at all_? Just stick with an old CPU.
Unrealistic? AMD themselves said there would be an IPC increase over previous gen chips.....it gets beat by older chips. You expected older chips to be able to do better than in?
I get all that, I just fail to see what I am doing on my PC that is only single threaded where I would really be missing out. Anything that I'm likely to do that is heavily CPU intensive, BD (and the X6 chips to some degree) does well at because they tend to be proper multi-threaded apps.
Yet the 8 core BD is performing about the same or worse than the x6 core Phenom IIs in cinema 4d, which is about as multithread efficient as anything out there......
A 'module' isn't 2 real cores either is it?
That's why i would like to see a 12 core Bull.
Make the 8150 £99 and it's an ok buy, but £200, no, just no.
Because more threads is better for proper CPU intensive applications, so it may well suit the user. No?
Daniel Berenbaum
“It’s difficult to recommend aggressively shorting AMD with the stock already at $5, but we maintain our view that AMD is being structurally squeezed by poor competitive positioning and longstanding operational struggles,” he writes. “AMD is on the verge of sinking into irrelevancy as ARM-based competitors gain share in low-end computing and Intel extends its advantages in performance and manufacturing.
“It’s difficult to remember the last product AMD launched on time, and it is now evident that, even aside from manufacturing challenges with partner GlobalFoundries, AMD’s technology roadmap is severely lagging,” he writes. “Third-party reviews indicate that the performance of new products based on the Bulldozer architecture is disappointing – this means that AMD will likely remain a bystander in the ongoing data center build cycle (which has accrued significant benefit to Intel), and will now also miss a window to compete in consumer PCs.”
Looks as thou AMD share price has dropped all the way from to $9 to $4.90 since the rumours of the poor performance started floating around the web. Not looking good.
Source
I can't see where it says when it was at $9 because doubt that it lost that in that time and was going down before hand.
