Here we go.
This is what I started with:
that looks quite similar to how my garage was, except my garage is probably twice the size (still a single garage though) and it was actually filled from top to the roof, it took 2 weeks to clear through it all, seriously it was a tough job, but it had to be done.
By the end of that day, I had this:
And the next day was this:
If anyone's ever been to StrengthShop.co.uk, they'll recognise that last shot. I bought the bar from them and sent Brian (owner) the photo.
Well, it hasn't been that tidy since. At them moment it's full of **** and I need to clean it out this summer and take some more photos with the mat and squat rack in.
i have recommended those strength shop mats in this thread several times
but i also recommend doubling them up because the rubber is not "solid" it's bits compressed together, most likely recycled rubber from tyres and they are quite thin, compared to my 17mm solid rubber mats.
if i was you i would get some WD-40, an old pair of socks and some rustoleum primer and rustoleum paint and some rustoleum clear coat for finish from B and Q or Homebase or Amazon and follow my re-furb guide, in this here thread.
i mean for the cost of £20-£30 you could get all your equipment looking brand new again and it will last a lot longer and be more pleasant on the eye too.
i think i used 8 cans of spray paint altogether but i did have tons to do. half a set of dumbells, 200kg of weight, a oly plate and bar storage rack. homebase also had a deal on at the time buy 1 can 2nd can half price, so look out for stuff like that too.
I got matting - made a mistake and got some 'gym' matting that locked together from ebay...
found out it was bloody EVA/foam after it was delivered! Still, for £40, it was just about enough to cover the area twice over so it was about 2cm thick, and it does mean I can drop weights without leaving a mark if necessary! Probably could do with getting some more though as actually it isn't half bad, but maybe rubber would have been better to start off with?
It's been assembled for the last 2 weeks actually - I'll give the place a clean up and get some photos - TBH I was really wanting to get some stuff from ebay but with the hassle of having to travel to pick up, having to compromise or wait a long long time, having to travel to several places - it made more sense to get this stuff for the price I did, brand new, exactly what I wanted all in one go.
I must say I only did get this setup as I started a new job and wasn't able to go to the gym - it meant I was paying £45 a month and going probably twice a month for the last 6 months - how I wish I had cancelled from the beginning - I'd be a quarter of the way there! The great thing is even if I do move house, if I do come to sell, after the gym fees I've saved have been factored in and also the fact I got it so cheap, I probably will be no worse off financially and have been able to go every day vs twice a month! Win win!
EVA foam is definitely not as good, a lot of people buy that because it's cheaper and lighter, etc, but there is a reason why it's cheaper, over time it will deform, etc. basically if you buy cheap you end up buying twice, whereas with rubber it should last pretty much forever. however it's done now, i would suggest you just keep it and see how long it lasts, it may give you quite a few years use since you have doubled it up. i think deadlifts is what will let you know for sure how long it will last, once your dropping 150kg+ onto them, then they will show their true worth.
or you could just buy the rubber matting from strength shop and then use that as the top layer of the double, essentially that would mean that you wouldn't need to double up on the rubber as the foam would help out a lot.
PM's need trust to be enabled i think, i think for that you need to have 1000 posts now and been a member for like a year, the rules have changed, it used to be 250 posts and 3 months i believe but i dont know if that's for trust or members market or both.
anyway you should get some pics up so other members can admire your brand spanking new setup
, im sure many will be jealous.
