Hi All,
Has anyone tryed the 501 bios yet?
Dose it clear up any of the RAM compatability issues?
http://support.asus.com/download/download.aspx?model=Rampage%20Extreme&SLanguage=en-us
Just checked again and the 501 bios is showing again
Hi All,
I think you'd be ****ing nuts to spend £900 on a processor right now when the brand new architecture is due out in a couple of months.
Would need to be a very very good price since its resale value will drop like a stone once i7 hits the market.
Everything else looks grand. And personally I would go for the Thermalright Ultra 120 Extreme.
Some updates from here.
A couple of days ago i installed a new Rampage Extreme. This is shipped with the 301 Bios!
His behavior with voltages is very different from my previous board, this need more Vdimm and NB volts and less Vcore and VTT volts for the same stability. But i must add that in this latter board i do not have made almost none cooling mods, only 2 washers below NB. (Still waiting the cooling kit from Enzotech and Thermalright)
Smirnoff posted the following GSkill modules are compatible (see post No1 of thread).
Thread contributors who are using either of these modules, i am sure will give you feedback regarding performance ect
G.Skill 2GB (2x1GB) DDR3 1600Mhz
http://www.overclockers.co.uk/showp...GB) CAS7 Dual Channel Kit (F3-12800CL7D-2GBHZ)
G.Skill 4GB (2x2GB) DDR3 1600Mhz
http://www.overclockers.co.uk/showp...GB) CAS7 Dual Channel Kit (F3-12800CL7D-4GBHZ)
http://www.overclockers.co.uk/showp...GB) CAS7 Dual Channel Kit (F3-12800CL7D-4GBPI)
Are you going to update from the 301 Bios? The need for more vdimm, NB bridge volts including VC and VTT V+. (This is a Bios issue)
Are you able to update regarding performance and testing of this board in comparison to the previous board before the RMA? As you mentioned the RAM problems with the blue slots
Thanks for that reply, that has sort of put my mind at rest![]()
Np. let us know how you get on with the Gskills, and benchies![]()
Will do as soon as i get this bucket of bolts up and running![]()
Will you be updating to Bios 501?
My conclusions about the voltages are on 403 Bios, not 301. In exactly the same conditions and with the same Bios, in this second mobo i need more NB and Vdimm and less Vcore and Vtt. I have not yet tested the 501 bios, for lack of time.Are you going to update from the 301 Bios? The need for more vdimm, NB bridge volts including VC and VTT V+. (This is a Bios issue)
