Official Rampage Extreme Review/Overclock/Guide Thread
New Swiftech chipset block soon to be released :)
I was looking at Mips w/bs for the RE today. Is there a release date for the Swiftech chipset block, does it include south bridge or just the NB. Nice information again Smirnoff;)
Is this Cellshock ram one of the better DDR3 options at the moment? Its the last thing I need to decide on (buying this board and have never seen that ram before).
Cellshock probably make the best DDR3 sticks at the moment. There DDR2 range was legendary :) Get the board first as you can always DSR the ram back if you dont like it.
sorry no screenshots at moment still cannt get them to load from imageshack also had to rebuild xp corrupted at 5.7mhz have had memory upto 2010 before then dropped it back to 1920 at 1.7v 333 strap leave everything on auto and works fine have tested some other cellshock and they just same memory is low volt but n/b 1.75 sb at 1.8 both these non stock w/blocks can only run 1 card as pipes in the way of second card have also tried some corsair 1600cd9dhx and they working ok at up to 1640 couldt get to boot over that no matter what strap i used ,these would not boot with 2 x sticks in blackops p## the cellshock like bios 403 i tried the newer ones but had probs with cpu went back to 403 and it ok:)
i think i understood all that - what CPU ram are you using ?
Roller What were the timings for the memory at 2010, again at 1920. Are these modules CellShock 1866MHz PC3-15000 1866MHz Stock Timings of 8-8-8-16 at 1.7V-2.0V. using Micron D9JNL chips?
Which CellShock modules are these Roller you are referring to? can you include more information such as timings and micron?D9JNL or D9GTR?
Thanks for that information regarding Bios 403
hi memory cellshockCS3222770 1866
` 9-9-9-20 1.7v loose timings never altered settings from day 1
as you no quads dont like high fsb well the l8tr ones with the high 1600 fsb
so have been concentrating on getting the most i can get before they go back to where they came from still cannt get anything up from imageshack dont have prob with xs i altered the strap by accident when up to 2000+but all other settings were the same the ram overvolts as you up th n/b so prob the volts would be up 1.8+ never checked as busy with cascade i am going to do more tests t-morrow if i send to you @Mail can you put them up if possible
These are the pics Roller has sent me for posting:
Hi on this screen (Ramp1) you will see i have dropped the fsb slightly due to XP crashing. So for the time being having to use vista (See Vista1.2.)
For some reason FSB 483 and above it fails on core 2. Core 2 was functioning yesterday. I think CPU/ Core2 is degrading!
I lost a lot of bench screen shots using XP, i have not yet been able to recover the pis.
I have included a couple of screen shots using a Black Ops motherboard (Vista1 & 2 screen shots). Same chip and memory. These last 2 pics show the only stable FSB i could possibly attain, as i have to test for stability and not outright speed. Regards Roller
RampEx1.
Foxcon Black Ops Vista1.
Foxcon Black Ops Vista2
Just put my order in for this board with the shop and got free delivery :)
Will let you know how i get on when she arrives. :D
