Official Rampage Extreme Review/Overclock/Guide Thread
Here you go got some piccys done.
My cellshock sitting happy in the rampage :)
And some of my bench table,fans galore:D
Thermochill pa 120.3 fitted to cool my cpu only when i pick a new waterblock.
hi i would advise you to w/cool the north bridge as well mine is w/cooled and still at 56c with a different block on and i changed all the compound before i fired it up mind this is if you are going to put xtra v thru it mine is at 1.7:)
what block are you using? are you watercooling the SB?
the n/b is a modified innovatek the s/b is still linked to heatpipe as i am on modifying a block for it as everything that is available there no room for dual cards we are designing a loop to go where the heatpipe goes with 1 inlet at one end and outlet at other like what is coming on a foxconn board(future)
Ive seen in reviews that its possible to use the board without removing the north bridge waterblock, anyone care to test it and see what kind of temps it produces?
can you tell me what is highest fsb you have got on 403 ive put 404 on and with a few tweaks managed 8 more stable on the fsb trying to break the 500 barrier getting there thanks :cool:
mate can you post some pics of your custom setup?
With 0403 i could break 520 FSB with a q9650 didnt try much higher as i didnt want to corrupt my raid array, The board needed a lot of NB volts to get over 500 FSB tho.
Is the Fusion block okay for watercooling the NB, or is it better to strip it down and just use separate blocks ?
