Official Rampage Extreme Review/Overclock/Guide Thread
Here you go got some piccys done.
My cellshock sitting happy in the rampage :)
And some of my bench table,fans galore:D
Thermochill pa 120.3 fitted to cool my cpu only when i pick a new waterblock.
Nice set up Clone m8. Love the Dimos bench :cool: On the verge of ordering mine;).
Im interested in the CellShock benchies as i have the 1800s (black heat spreader)
Well its made of aluminum and had the the stupid little 8m/10m asus barbs on it, I wouldnt really recoment using it lol
The block i think is solid copper apart from the barbs which are aluminium? I may be wrong?
Price Increase for this board :(
Ocuk had the board originally listed for £258-00 inc. This weekend just passed 16-17/8 was on special offer (weekend only).
Just checked OcUK website, yet again OcUK have continued the special offer price of £199-00 exc , £218-00 inc (£40-00) saving on their original list price. Its good to see OcUK have seen fit to extend their special offer beyond the weekend deadline. Another major competitor has the board for £246-00 inc.
Some shots of my board setup for air cooling, I'm hopeing EK will make a special block that will cool the northbridge and the extra stuff around it :D
Any aluminium is bad in my view lol
:D I am in total agreement with you Smirnoff m8. I am going to order a Mips NB block, including a KTC block as i have wanted to test one out for some time.
Edit: Is there a release date for the swift tech NB block as of yet?
Swiftech rep was saying around 3 to 4 weeks. Are Mips doing a specal block or is it a standard NB block ?
10mm is 3/8".
I was able to get soft Tygon 8/11 over the ones on the Maximus Formula SE, but standard PVC 8/10mm tubing needed to use one of the convertors.
Mips are doing a straight NB WB to replace the fusion block. either Two types either all solid copper or nickel plated.
2-4 weeks for the ST, Mips take 10 days to two weeks, and are made to order.
Mips are also doing the complete set of blocks as well including mofsets made to order either all copper or nickel plated
Can anyone do me a quick favor and let me know about this board:
Im guessing its the normal ddr2 version but I dont know if there are any other rampage boards out there I dont know about :confused:
That appears to be a Asus Maximus Formula Intel X38 (Socket 775) PCI-Express DDR2 Motherboard
Specs:
- Intel® Quad-core CPU Ready
- Supports Intel® next generation 45nm Multi-core CPU
- Intel® Core™2 Extreme / Core™2 Duo Ready
- Intel® X38/ICH9R
- Dual-channel DDR2 1066/800/667 MHz Support
- 1333 / 1066 / 800 MHz FSB
- Extreme Tweaker
- SupremeFX II 8-CH Audio
- CPU Level Up
- Voltiminder LED
- LCD Poster
- ASUS EPU (Energy Processing Unit)
- 2-Phase DDR2
- COP EX
This motherboard supports the latest Intel® Core™2 processors in LGA775 package. It also can support Intel® next generation 45nm Multi-Core CPU. With new Intel® Core™ microarchitecture technology and 1333 / 1066 / 800 MHz FSB, Intel® Core™2 processor is one of the most powerful and energy efficient CPU in the world. The Intel® X38 Express Chipset is the latest chipset designed to support the next generation 45nm CPU in high-end desktop and workstation platform; and up to 8GB of dual-channel DDR2 1066(oc)/800/667 MHz memory architecture. It also supports 1333/1066/800 FSB (Front Side Bus), fully dual PCI Express x16 graphics and multi-core CPUs. scale down screen resolutions to get the high image quality you want. CrossFire ignites with the higher antialiasing, anisotropic filtering, shading, and texture settings you desire. Adjust your display configurations, experiment with your advanced 3D settings, and check the effect with a real-time 3D-rendered preview within ATI´s Catalyst™ Control Center to rule your CrossFire
(The Asus Maximus Extreme (x38chipset) supports DDR3)
Specs:
- 1600 / 1333 / 1066 / 800 MHz FSB Support
- Intel® X38/ICH9R
- Dual-channel 1800(O.C)/1600(O.C.)/1333/1066 Mhz DDR3 Support
- Fusion Block System
- Extreme Tweaker
- CPU Level Up
- Voltiminder LED
- LCD Poster
- COP EX
http://www.overclockers.co.uk/showp...X38 (Socket 775) PCI-Express DDR3 Motherboard
The Asus Maximus II Formula LGA775, P45 Chipset Supports DDR2, Cfire, Snd, GBLan,ATX
Specs:
LGA775 socket for Intel® Core™2 Quad/Core™2 Extreme/Core™2 Duo/Pentium® dual-core/Celeron® dual-core/Celeron® Processors
- Supports Intel® 45nm Multi-Core CPU
- Intel P45/ICH10R with Intel® Fast Memory Access(FMA) support.
- FSB 1600/1333/1066/800 MHz
- 4 x DIMM, max. 16GB, DDR2 1200/1066/800/667MHz, non-ECC, un-buffered memory
- Dual channel memory architecture
- 2 x PCI Express 2.0 x16 slots, supporting ATI CrossFireX technology
- 3 x PCIe x1
- 2 x PCI
- Support ATI CrossFireX technology
- 6 x SATA 3Gb/s Intel® Matrix Storage Technology with RAID 0, 1, 5, 10 support
- 1 x UltraDMA 133/100/66 for up to 2 PATA devices
- 1 x External SATA 3Gb/s port (SATA On-the-Go)
- 2 x Silicon Image Sil5723 SATA 3Gb/s
- Dual Gigabit LAN controllers
- SupremeFX X-Fi Audio Card (ADI AD2000B 8-channel High Definition Audio CODEC)
- Coaxial/Optical S/PDIF out ports at back I/O
- Max. 12 USB2.0/1.1 ports(4 ports at mid-board, 6 ports at back panel)
- ASUS 16-Phase Power Design
- CPU Level Up
- LCD Poster
- Onboard Switches
The difference between the two boards is x38/P45 chipset either supporting DDR2 or DDR3.
http://www.overclockers.co.uk/showp...P45 (Socket 775) PCI-Express DDR2 Motherboard
