any of these cards known for a failing fan? my brother has had an xfx 5850 since launch and got one of these saphires the other day but has had nothing but problems with it.
at first the sapphire wouldn't run at full speed and kept dropping to 2d clocks, i installed afterburner to fix that and now both cards run at full speed when gaming and the fan runs ok too once it's loaded.
heat was a big problem so he installed a h50-1 today to help keep case temps lower for the cards but now the sapphire is cutting out again before windows even boots so afterburner can't get the fan on in time and he has to remove that card to get the pc to boot again.
is it a case of flashing it to renove fan profiles or just send it back?
edit: should also mention that most of the times the CCC dont work properly either as its usually a blank page :/
