OLED 4K 30" 60 Hz - Dell UP3017Q
12 Dec 2010
Washington D.C.
http://www.overclock.net/content/type/61/id/3008572/
** Do Not Hotlink Images **
Overview
Realistic beyond belief. Color beyond compare.
Experience vivid color against true black on our first OLED monitor. Featuring a 30-inch Ultra HD 4K screen with PremierColor.
Beautifully lifelike: Images are intensely real against OLED’s true black with the highest contrast ratio yet – at 1,000,000:1.
Greater depth and detail:Magnify every hue with PremierColor qualities for precise, factory-calibrated color.
Outstanding connectivity and design:A single USB Type-C cable eliminates clutter, transmits Ultra HD 4K signals and audio, and supplies power to your laptop.
Unmatched reliability:Count on dependability with a Premium Panel Guarantee from the world’s No. 1 monitor brand.
Manufacturer Part# : J3CJM
Dell Part# : 210-AIEI
Tech Specs
Display
Diagonally Viewable Size
76.19 cm (30 inches)
Preset Display Area (H X V)
699.86 mm x 379.22 mm
27.55 inches x 14.93 inches
265400.90 mm2 (411.32 inches2 )
Aspect Ratio
16:9
Panel Type, Surface
OLED
Maximum Preset Resolution
3840 x 2160 at 60 Hz
Curve radius (if applicable)
NA
Border Width (Edge of Monitor active area)
11mm (Top/Left/Right). 16mm (Bottom)
Viewing Angle:
178° vertical / 178° horizontal
Pixel Pitch
0.173 mm x 0.173 mm
Pixel Per Inch (PPI)
147
Contrast Ratio
1000,000:13
Backlight Technology
NA
Brightness
300 cd/m2 (typical) / 0.0005 cd/m2 (min)
Response Time
0.1 ms (black to white)
Wireless Charging Feature
NA
G-SYNC Suupport
NA
PbP/PiP
PbP (No)
PiP (No)
Daisy Chain Availability
No
Dell Display Manager Compatibility
Yes with Easy Arrange
Remote Asset Management
Yes, via Dell Command
Color Support
Color Gamut (typical):
Adobe RGB 100%
Rec709 100%
DCI-P3 97.5%
Rec2020 85.8%
Color
Depth:
1.07 Billion colors (10 Bits)
Color Calibration SDK SW
No
Color Calibration with X-rite colorimeter
No
Display Screen Coating:
AR (Anti-Reflection) reflectivity: 4.5% Hardness 2H
Audio Output:
No
General
Connectivity
mDP (1.2)
HDMI (2.0)
USB Type C
What's in the box
Monitor with stand
Power cable and adapter
1 x mDP -DP cable
1 x mDP -mDP cable
1 x HDMI Cable
1 x USB type C cable (C to A)
1 x USB type C cable (C to C)
1 x USB Type C Holder
Cleaning cloth
Drivers and documentation media
Quick setup guide
Safety Information
Stand
Vertical Stand Extension (100 mm)
Tilt (5°/21°)
Swivel
Pivot( clockwise / counter clockwise)
Built in cable-management
Flat Panel Mount Interface: VESA (100 mm)
Built-in Devices
USB Type C (Alternate mode with DP1.2, Power Delivery PD up to 100W)
Security
Security lock slot (cable lock sold separately)
Anti-theft stand lock slot (to panel)
Compliance and Standards
TCO Certified Displays
RoHS Compliant
Service/Support Details
3-Year Advanced Exchange Service with Premium Panel Guarantee and Dell Prosupport
Size and Weight
Dimensions with stand (H x W x D):
Height: Compressed : 456.3 mm (17.96 inches), Extended : 556.3 mm (21.90 inches)
Width: 686.2 mm (27.02 inches)
Depth: 191.6 mm (7.54 inches)
Dimensions without stand (H x W x D):
Height: 405.4 mm (15.96 inches)
Depth: 44.7 mm (1.76 inches)
Weight
With packaging: 19.31 kg (42.56 lb)
Panel only: 6.43 kg (14.17 lb)
Electrical
Voltage Required:
100-240V AC / 50 or 60 Hz ± 3 Hz / 3A (maximum)
Power Consumption (Operational):
105W (typical) / 240W (maximum)
Power Consumption Stand by / Sleep
Less than 0.5W
Environmental
Temperature Range
Operating: 0°C to 35°C (32°F to 95°F)
Non-operating: –20°C to 60°C (–4°F to 140°F)
Humidity Range
Operating: 10% to 80% (non-condensing)
Non-Operating:5% to 90% (non-condensing)
Altitude
Operating: 5,000 m (16,404 ft) max
Non-Operating: 12,191 m (40,000 ft) max
Look's like they redesigned the prototype. 60 Hz now instead of 120 Hz but at least they put DP 1.2 and HDMI 2.0 on it. Can't wait to get this baby in. Hopefully the input lag is low!
Finally! Well done dell for pushing the monitor market forward rather than stagnating on milking the same old basic LCD panels...
Would love to buy this to support them but not when I could get a 4k hdr 55" oled TV for £1600....
Nice. I look forward to hearing your experience :)
Not just Anandtech, that is what is indicated on Dell's website. :)
Will you be reviewing this monitor? :p
amazed that we have oled here for monitors finally , thats great news but whats with the price ... have i missed something ?
30" dell 60hz 3500$
as above 4k hdr 55 oled £1600 60hz
what tech could the dell possibly have over a 55 oled tv which doubles the price and gives you half the screen estate ?
It is called milk tech. ;) :D :p
I expect the price to plummet within the year due to the sheer lack of sales that they will get, unless they will be aiming this purely towards the extreme high end professional market like Sony's OLED monitors.
But yeah the price is confusing especially since the previous version was suppose to 120HZ 4k (iirc) yet was only about $500 dollars more (iirc)
60Hz... Thanks but no thanks. I'll wait for second generation OLED monitors which will probably be both cheaper and have better features like GSync and 120/144Hz.
It is milk tech indeed. Price skimming and they can do it easily as they are first to market. Price will come down eventually.
30" dell 60hz 3500$
It's the pixel shifting technology. You should not use OLED TVs as monitors because of static image burn-in issue that all OLEDs have. This is one of the trickiest things that slowed down the adoption of OLEDs for computers and laptops.
I will take 60hz any day if it means I get much better image quality. No backlight bleed, IPS glow rubbish. Just wish it had freesync at least.
+1
And expect to see freesync in the next version, milking is a fine art and it has to be done right ;)
- this year, just the bog standard panel itself
- next next years model, maybe 75+HZ or/and free/g sync and 32"+
- year after that, without a doubt, 144+HZ and/or free + gsync
Why give the people everything in one try when they can get people to either double or triple dip!!! :D
The 2016 and newer OLEDs have solved the burn in (well it is still there but nowhere to the same extent and they have found a way to remove any substantial burn in), iirc, it was something to do with resetting the voltage and I believe whatever the program is, it runs when the TV is in standby, they also have some form of software that shifts the pixels to the left/right every now and then.
Although how this will work with static items/images on desktop/windows usage remains to be seen....
was this not canned in Jan 2017?
Because OP forgot to link the article see: http://www.anandtech.com/show/11272/dells-ultrasharp-30inch-4k-oled-now-on-sale-up3017q-for-3500
One of the biggest bits of news to come out of CES 2016, over a year ago, was Dell announcing a new beacon in OLED monitors: a 3840x2160 panel measuring 30-inch diagonal using an OLED display was set to come to market. When we reported on it back at CES, they stated a $4999 price point for March 31st. What happened over the next 12 months was interesting: some journalists doing ‘hands-on’ reviews at tech shows, but nothing coming to retail, followed by plenty of CES 2017 news that the display had been shelved due to image quality issues. Well roll around another quarter, and it seems that Dell is ready to sell it, and shipping for this $3499 beast is only 1-2 weeks away.
The product page on Dell's site: http://www.dell.com/en-us/shop/accessories/apd/210-aiei?c=us&l=en&s=dhs&cs=19&sku=210-AIEI
I'm so happy an OLED monitor is finally hitting the market, even if it doesn't have all the bells and whistles I'm looking for. Hopefully it gives higher ups at other monitor manufacturers *cough* LG *cough* a kick in the backside.
