I read the
hdtvtest ub900 review for the first time, it (like french ub900) acknowldeges there is image processing by uhd players,
so the output bitstreams are not the same from all players - agree/disagree. ?
I think no-one has 4k captures, maybe because folks are not interested, or for a bona-fide site it would show they were using hdcp stripping.
The images in the french review, discuss oppo vs pan rendering of clouds, that was what caught my eye about the German, xbox pictures
even though, like all, they are not 4k captures, a small resolution image (the French ones are not enormous) they can show differences.
There are not enough images though on the de site.
The french comparsion images do show, subtle image improvemenst, as a result of Pany processing (not exploiting the chroma upscaling), which are changing output bit stream
(eg the tiger) the xbox in comparison does not have similar switches/options.
so the panasonic can change the output bitstream, in a manner benecficial to the image, and it would be different to the xbox one s stream.
Unless you haved both players in front of you you would probably be happy with either.
