Yeah I'm covering most of that - the plan is 2x 470uF (per rail) Cornell Dubilier MLQ series AE cap bank then 0.1uF then LM317/337 pair that supplies 220uF Nichicon KZs (one for each rail) decoupling caps as well as the 0.1uF decoupling caps near the opamp supply pins.
Optionally between the cap bank and the 0.1uF before the regulator possibly a 100-200uH inductor with a (protective) diode to ground before it but I'm not really very familiar with inductors so I'm not 100% if I'm going to do that or not - badly done there is the potential for wire melting incidents with the inductor hence the diode
