Man of Honour
There shouldn't be any corrosion with X1 so something weird is going on here. There's no kill coil in the loop is there?
I wouldn't be using vinegar at all, hence my suggestion of Part 1 and then distilled, which you say came out clean?
The next step should have been part 2, which would neutralise any remaining residue and balance the PH ready for final thorough rinsing, then filling.
To clarify, you used Part 1, it was clear after full rinsing, and then you used vinegar? How come?
I'd be giving it a very, very thorough rinse with distilled, as you've essentially added a contaminant & acid, then try a full Part 2 run to see what the fluid is like after draining, and then rinsing.
Stop using vinegar dude.
You're seeing aqueous copper acetate from the vinegar (acetic acid) reacting with the copper.Would you agree with @LePhuronn that the fluid coming out of my radiators is greenish/blueish/turquoise simply from the vinegar reacting with the copper rather than from the vinegar dissolving corrosion?
Personally, I've never flushed any of my kit with anything other than copious quantities of very hot tap water and vigorous shaking. Not that I recommend it for anyone else, I've always used the same concentrated coolant used in my car in my pc for the last 7 years at a weaker dilution ratio. I've not had so much as a hint of corrosion in that time. Clearly something with that X1 premix that you used wasn't right or something chemically reacted with it which rendered it's corrosion inhibitors useless.
The part 1 came out greenish/blue, flushing it with plain water was clear. After I posted those results Pasty recommended I continue flushing with vinegar to see if more colour comes out.
I can't access imgur at work (boo hiss to slowly transitioning back to the office ) but I have a feeling this could be your first piece of actual bad news.Anyone have any suggestions on how to clean this?
https://imgur.com/a/3optObD
Hopefully you can see the ring of grime where the o-ring goes. So far a toothbrush and water has done nothing at all. I dont want to use any chemicals because i dont what's safe to use on acrylic.
Thanks.
@LePhuronn
It's actually the bottom section of my EK pump/res combo. I've soaked it in hot soapy water and i'm able to remove some of the gunk/stain with a soft sponge (i can see it on the sponge) although the acrylic part never actually seems to look any better.
Speaking of the pump/res i need to replace both o-rings as they turned a horrible shade of puke green. The only place to buy them is from EK directly but they want 13 Euros delivery!
These are the ones I need and i've tried looking for them to purchase in the UK.
The closest i've found is 52x3 and NBR70. I've no idea how critical it is get ones that are NBR50 as per the EK specifications.
That's much better, not perfect but I don't think you will get it much better than that. Take the O-ring out of the top and then clean it. It should come out easily enough. Do not use Lime and Grime on the gpu block as it should not be used on nickel or chrome.
