Caporegime
- 11 Mar 2005
- Leafy Cheshire
I know from experience never to boast about how reliable my German car is, it always ends in an expensive pool of tears.
and i think, especially on new cars like that, the owners are particularly clueless so cannot use their own judgement about whether its safe/worthwhile to do this or that to their cars.
"IF" the box is only rated to 300lbft youd have to be a window licking spastic to hope itll take 560lbft. id even worry about 380lbft.
IMO buy german stuff. certain components seem to be bomb proof. the gearbox on my car (standard 150bhp) typically ends up on turbo'd cars making way over 300bhp and torque without breaking a sweat
3) go to a tuner, and get a limited slip differential. Most of that £900 cost is labour, which you can effectively have for free when taking the gearbox out to fit an LSD. However LSD will already be about £1100 fitted, plus the £200 clutch. so not cheap, but £1300 for new clutch and LSD from a tuner, vs £900 from a dealer seems quite cheap.
the diesel and 20vt golfs start to suffer that when the clutches start to become old, but thats mainly down to the power delivery delivering the torque in a sharp spike.suffer clutch slip when mapped (full throttle @low revs)
The RS clutch is much stronger than the ST item though.
This is kind of interesting.
But then courtenay were the ones who told me nobody burnt out clutches and an upgraded one wasnt necessary. Dont know what to believe anymore. Suffice to say, this has put me well off tuning.
Tuning companies will swear blind that their mods are perfectly safe. It's how they secure customers.
It's only through experience that you learn this is never the case. Any significant mod will always have side effects elsewhere.
Even just fitting a new sports exhaust (which is a pretty simple mod for anyone to make) can cause annoying heatshield rattles and reverberance/rattles with the interior. Of course these are just annoyances but they're things that tuners won't bother to mention.
Courtney certained used to be a bunch of cowboys so it's hardly likely they'd mention any problems.
Oh my - How many peoples gearboxes have gone bang then MrLOL? You keep mentioning what the gearbox is rated to, yet I've never seen anyone have a problem with either M32 or M40 box?
Dont know which tuners to believe anymore (clue - none!). Suffice to say, this has put me well off tuning without providing supporting modifications.
Muncher swears by them, as do plenty of other VX220 owners. Some of the major criticisms aimed at tuners, of offering products you dont need - they dont do. They also dont fudge dyno results to make their results better. Their dyno is deliberately one of the harshest around and is most certainly not know for over reading. What "cowboy" antics have they been known for in the past ?
