well arent you a condescending little **** today ?
As ive already previously stated. The gearbox is rated to 400NM constant torque (approx 300 lb/ft) the car puts out 260 lb/ft as standard. The remap takes it to 400 lb/ft, but it only puts out more than 300 lb/ft on a small portion of the rev range (2500 rpm to 5000rpm)
http://i130.photobucket.com/albums/p279/mrlol_album/Vectra VXR/P1020282.jpg
Theory is, its rated to higher than 300 lb/ft for occasional torque, but should take 300 lb/ft all day every day so you should in theory be safe. Obviously in practice thats not the case, but theres no need to be a **** and call me retarded.
2500rpm to 5000rpm is quite a large portion of the rev range. Especially as its peaks nearly 100lb/ft over the rated amount.
Kinda lucky the clutch went tho, as im betting and uprated one will just blow the gearbox.
But anyways when remapping, always take into account that something may break and don'talways believe tuners.
Not having a go at you btw.
