If your download speed has increased, and your pings have increased, it is probably enabled for you.I presume that there is no way of telling whether it's been enabled if you have a HH5?
Getting jitter every time I do a ping test after G.INP has been enabled.
How do you tell if G.INP has been enabled? I understand that the ECI cabinets are going live as we speak but wondered if there's a tell-tale sign in the modem stats?
Using an unlocked HG612, if it helps![]()
I lost about 20% off the upstream with G.INP enabled on a 5A - the sync rate stayed where it always had but the maximum rate was a good 4Mbps lower.
Went over to my box of trial 5Bs and swapped it out, problem solved. 10ms to bbc.co.uk over Wi-Fi, and a solid 56/20 sync.
