Sounds like poor CPU to waterblock heat transfer or coolant is not circulating like it's supposed to.
Is the waterblock on CPU warmer to the touch than one of the hoses? (the hose carrying the coolant from pump to radiator) The hottest point in system should be the hose carrying coolant from CPU to radiator.
Reason I ask is because if pump motor is running you will feel / hear it but the pump impeller is not moving than no water is moving through the loop.. so no heat will move away from waterblock/cpu.
