- 21 Dec 2019
- Planet Thanet
Air flow will always make a difference certainly but at the same time a good loop should not sound like a jet engine eitherI made sure all the air has been drained from the loop, i have moved it around and ran it on a separate PSU when fitting to ensure it was running with no leaks before powering on so no bubbles in any blocks and the res is almost completely full and this level has not changed since fitting.
I do not have a flow meter but i did try the dye trick and zipped down the tube with no issues at all.
Its defo the GPU that is of the main concern, this is connected to the rad at the top of my case, my thoughts after reading all of your guys comments is that as the airflow is too low, the fans mounted to the front rad is not able to blow through enough air to get fresh air to the top rad to blow through and cool the GPU? Is that the right line of thinking or am i talking out my rear end?
Are you pushing air through radiators or pulling it through?
Never actually seen a scientifically based post on this so I could also be talking out my rear end here lol
But I prefer to push air through if possible ~might make no difference but pictured in my head it works better
And you can't test without your gpu just to see how cpu only fares since no integrated graphics and pain to take gpu out
I used some quick disconnects so can isolate cpu and gpu from rest of loop so can remove without draining down
