You spend £20 on a tyre which is the only contact between the road and your car?
Buying a second hard car has part worn tyres unless you instantly change them too.
No it doesn't. It has tyres that have done x mileage since new on the car. Not tyres removed from another vehicle with an unknown history and potentially terminal fault.
Unless of course the seller informs you that they are part worn tyres fitted to the car, in which case you've seriously got to question why you'd buy the car.
Buying a second hand car you still don't know the history of the tyres even if they have been on since new. Where they been, kept at correct pressure, how many puncture repairs, etc.
Buying a part-worn, god knows why they were removed, but I'd wager that most part-worns are removed for reasons beyond that of replacement due to normal wear and tear. I mean, who removes a perfectly serviceable tyre?
Would have been a cracking tyre if it didm't have the cut in it as tread depth is still 7mm.
ban!From here it already looks like a cracking tyre
To be fair on the past 3 or so cars I've bought which are second hand I've changed all four tyres within 6 weeks or so.Buying a second hard car has part worn tyres unless you instantly change them too.
