Started to map out the hard line...
Routing - idea is to frame around the board and card - would have been easier to just cut through them to be honest
Ball value at the end - have a pump that can force the liquid out for drain to not to fussed on it having to be at the lowest point. Missed a trick though, prob could have had it on the bottom far port of the bottom rad but i aint going to take it all apart again to do it - not for Frosted loop only- maybe when i had Mahems glass in
Most of the routing is based on lines running in parallel, with a glass/Frosted tubing combo to reflect the design off the parvum case
Bottom end... so tight! (oi oi)
Rad to res input - this will be glass in the end - already have pre-bent pieces which is a massive help!
The frosted tubing from the gpu to cpu will run parallel and offer the contrast
GPU
CPU- was torn on using either 90's or dual 45s. Using 90s would have meant using more extenders so went with the duals and adds from curved to a right angle build.
I wish alpha didnt engrave on the block otherwise would have rotated it 180 - still could do but having the text upside down would bug me to the core!
Staggered in height so output can frame the top edge of the board and into the far port on the front Rad. Input will cut over the top edge of the ram and down the edge of the mobo.
Pics with window panel on (still waiting on final 8mm thick one- using 3mm at the mo)
so this was all set in stone till i released I forgot to drop the the GPU to lower PCIe slot to show the Heatsink more...
So final Version - Green is the glass tubing , blue the frosted orange is flow wheel and red new fittings/change of location
But for the time being will stick with the first routing to give me a feel for hard tubing , which will all be in frosting. First time hard hard tubing to like to go in easy
