I think there is time for a small update before sleepy time, not everything just yet but a good chunk of progress to keep you all entertained, hopefully!
Straight in with the cutting at Parvum HQ, unusually we didn't actually use our swarf sucker for any of FURIA's parts. The reason for that was the tiny 1.5mm single flute tool used for the o-rings could barely reach out of the foot which surrounds the action. But on the positive side we got to see far more action.
So this is the first of 5 main layers which make up FURIA's monoblock, cut from 10mm frosted perspex this has all of the features from Bitspowers original CPU and motherboard block top.
And this is layer 2! Joining the coldplates together and sending the coolant off to where it needs to be for the next layer. It's sealed with just two 1.6mm o-rings and fills out all of the free space on the motherboard.
Screws, lots of screws, actually not 6-32 UNC this time but the rather more conventional M3 and M4 variety as used by Bitspower. Just nice simple oxide black steel screws with plain socket countersunk heads.
I actually changed the CPU block top design somewhat to allow for better packaging in the block. Coolant comes in through the centre, passes through the original jetplate and fins then leaves through both sides simultaneously not dissimilar to the original however rather than having the two sides then join asymmetrically they both flow out into the block with identical bends.
Time for layer 1 and layer 2 to be mated together. Actually I missed out a boring half day of work where I made all of the o-rings and tapped all the holes right here, but you've seen that before, right MATE?
At this point lots of the screws are missing because they thread into a coldplate, simultaneously applying pressure to multiple seals.
These are the original Bitspower parts going into the reworked block, the board block is M3 and the CPU M4.
First the jet plate presses into it's locating features, then the coldplate is placed over the top with original o-ring in place.
Much the same story for the motherboard block only without a jet plate.
Then flipped and lots more screws added, some of which were cut to length so they could utilize the most thread possible in the copper.
So this is the side which the motherboard sees.
And these are all of the components which went into the first major stage of the monoblock.
Once that was complete a 3rd layer was added, this is actually the only 15mm thick part in the build and is used to mate the two main parts together and leave a big enough gap for the GPU to fit in among it all.
5 M4x30mm screws attach layer 3 securely to layers 1 and 2. 4 further M4 threaded holes then attach the entire assembly to layers 4 and 5.
That pretty much completes this one tiny sub-assembly!
Just for some scale you can see it here mounted to the motherboard. The 4 pronounced screws hold it directly to the ILM socket, applying pressure to the CPU while smaller screws are inserted from the back of the board to mate it securely with the VRM's and chipset.
So there we go, phase 1, or 2 or whichever complete and presented!
JR
