PC Build advice
The Bitfenix is a nice case but you might want to look at a case which has a slightly better front intake, I given two options below and optional PSU as 1200w is way over-kill.
YOUR BASKET
1 x SuperFlower Leadex GOLD 850W Fully Modular "80 Plus Gold" Power Supply - Black £99.95
1 x Corsair Obsidian 450D High Airflow Mid-Tower Case (CC-9011049-WW) £91.99
1 x Corsair Carbide 300R Mid Tower Windowed Case - Black (CC-9011017-WW) £69.95
Total : £276.89 (includes shipping : £12.50).
What PSU do I need power wise 850w 1000w?
Thanks for your suggestion the reason for BitFenix is the Gold that's on it so the case matches the colour scheme
YOUR BASKET
2 x Sapphire Radeon R9 290 Tri-X 4096MB GDDR5 PCI-Express Graphics Card (11227-03-40G) £299.99 (£599.98)
1 x Logitech G27 Racing Wheel - PC / PS2 / PS3 (941-000093) £207.95
1 x Intel Core i5-4690K 3.50GHz (Devil's Canyon) Socket LGA1150 Processor - OEM £161.99
1 x Western Digital Black2 120GB SSD + 1TB HDD SATA 6Gb/s 64MB Cache - Retail (WD1001X06XDTL) HDD £158.99
1 x Asus Z87-PRO Intel Z87 (Socket 1150) DDR3 ATX Motherboard £147.95
1 x BitFenix Shinobi XL Full Tower Gaming Windowed Case - Black £129.95
1 x Razer Orbweaver Elite Mechanical Gaming Keypad - Blue Switch ** FREE WATCHDOGS GAME ** £117.95
1 x Microsoft Windows 8.1 Pro 64-Bit DVD - OEM (FQC-06949) £109.99
1 x Corsair Hydro H105 Extreme Performance Liquid CPU Cooler (CW-9060016-WW ) £89.99
1 x TeamGroup Vulcan GOLD 8GB (2x4GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (TLYD38G2400HC11CDC01) £65.99
1 x Zalman ZM-GM4 Knossos Gaming Mouse £41.99
1 x OcUK 22x DVD±RW SATA ReWriter (Black) - OEM £10.99
1 x BitFenix Mesh-Stripes for Shinobi XL Tower Case - Gold £8.99
1 x BitFenix Alchemy 24Pin ATX Extension 30cm - sleeved gold/black £7.99
1 x BitFenix Alchemy 8-Pin PCIe Extension 45cm - sleeved gold/black £6.98
1 x BitFenix Alchemy 6Pin PCIe Extension 45cm - sleeved gold/black £5.99
1 x BitFenix Alchemy 8Pin EPS12V Extension 45cm - sleeved gold/black £4.99
1 x BitFenix Logo for Shinobi Tower Case - Gold £1.98
Total : £1,907.26 (includes shipping : £22.20).
Here is revised version of the one above is their anything I missed or compatibility issues etc? Thanks for you help so far people.
A questions about Hybrid HDD(SSD and HDD) how do they work do they show up as separate HDD or partions? Are they easy to sort/make work. Also if they are two separate HDD does this mean I require two SATA III 6gbps cables? And finally do I need a special HDD mount to fit them in a bay or they just fit into a 3.5?
(I know, well at least I think I know their are two separate HDD just two in one HDD case)
I also know ive missed a PSU out getting one of another website due to it not being for sale despite it being in the "Ultima Bullion"
Also (I know I said this already :)) open to suggestions :)
Thanks again
There certainly a few thing i'd change.
The Hybird HDD is pretty poor, if the price was sub £100 it may be worth it but the price of SSD and HDD these day, you can get better for less money.
The case isn't the best choice.
The Motherboard is Pre-DC so may not work with the CPU, not good.
The Orbweaver is expensive but i have another option for you if you really want something like it.
The black gold theme is achieveable.
YOUR BASKET
1 x Gigabyte Z97X-UD3H-BK - Devil's Canyon Core i7 4790K CPU & Motherboard Bundle **£45 Saving** £356.98
1 x SuperFlower Leadex GOLD 1000W Fully Modular "80 Plus Gold" Power Supply - Black £129.95
1 x Crucial MX100 256GB SATA 2.5” 7mm SSD + 9.5mm Adapter (CT256MX100SSD1) £79.99
1 x Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST2000DM001) HDD £60.98
1 x Kingston HyperX 8GB (2x4GB) PC3-17100C11 2133MHz Dual Channel Kit - Black/Gold (HX21C11BGK2/8-OC) £59.99
1 x Razer Tartarus Expert USB Gaming Keypad £49.99
1 x Corsair Raptor M45 Gaming Mouse (CH-9000052-EU) £37.99
1 x Corsair AF120 Performance Series Low Noise High Airflow - Dual Pack (CO-9050004-WW) £22
1 x Corsair SP120 Quiet Series High Pressure Low Noise - Dual Pack (CO-9050006-WW) £22
1 x Corsair AF140 Quiet Series Low Noise High Airflow - Single Pack (CO-9050009-WW) £14.99
1 x Silverstone Cable Extension Value Bundle - Black & Gold £13.16
1 x Silverstone PCI 8-Pin to 6 +2- pin PCIe Cable 25 cm - Black / Gold £4.24
1 x Silverstone 4-pin Molex to 4x SATA cable 30 cm - Black / Gold £6.77
1 x LiteOn IHAS124-14 24x DVD±RW SATA ReWriter (Black) - OEM £11.99
2 x Silverstone PCI 8-Pin to 6 +2- pin PCIe Cable 25 cm - Black / Gold £4.24 (£8.48)
Total : £2,003.83 (includes shipping : £16.85).
On the fans you can either use the white rings or get some gold spray and spray them (as they fully remove it won't affect performance in any way, a lot of people have done it). :)
YOUR BASKET
Thanks for this the reason for the case I selected is for the colour scheme gold trim. Why is the case I selected so bad?
Also the motherboard I selected you mentioned is pre Dc what does pre dc mean
I see the reaosn for the gold trim... Im not saying you should go with the Shinobi XL, as it does givve you the scheme you want but the 450D (and a few other cases) perform better and are much cheaper than the XL. Just something to consider but if you're 100% set on the gold trim, go for it.
Sorry, DC means Devils Canyon, The Z97 chipset was release specifically for Devils Canyon Chips, the 4690k and 4790k.. ect..
Thanks for explanation so what a the benefits of the Z97 chip set over the z87 chipset
