Have you looked at the event viewer yet?The system does not freeze now but after about 10-15 it's just unresponsive nothing I do registers
Does this help at all?I am looking into event viewer as we speak, the motherboard booted into the recovery bios itself and shows the orange led how do you get out of the recovery and into the normal bios
I had this occur on my Gigabyte X570 Aorus Master. On the motherboard there are two slider switches. One is for setting dual vs single bios mode and another is for setting master vs backup bios for the two chips. First, turn off your computer and make sure no power is applied (turn off the psu or pull the plug). Second, slide the switch to single mode. Then you can try to boot. I had overclocked my memory and it would not boot, therefore, I used the clear cmos method. Again unplug, and press the clear cmos button. Plug back in and reboot, you should be in master. You can even change the single mode back to dual and then it should boot the master bios. You'll need to go back in and setup your config. Hope this helps.
Sometimes you just can't pinpoint the problem and it's worth doing a fresh install if windows.i jave searched these erros and done what it suggested but no luck, i have tried uninstalling CAM, doing a memory test, checked system files.
I've uninstalled the AMD chipset drivers to see if these were the problem, after uninstalling I got a blue screen but then the system restarted normally. i am just waiting to see if the problem happeens again.
Did you completly uninstall the old AMD chipset drivers first.Funny thing I tried to install AMD Chipset drivers today and soon as the setup started the system became unresponsive,
Anyone had any issues with these?
This may have been part of my problem
