- 1 Dec 2015
Can I go with 4 packs of Corsair LL120 RGB, 120mm Dual Light Loop RGB LED PWM Fan, 3 Fan Pack with Lighting Node PRO since I will spare some money?
You could... But each lighting node takes up a usb 2 internal header ...
https://www.corsair.com/uk/en/Categ...INK/CORSAIR-Lighting-Node-PRO/p/CL-9011109-WW
What you can do is use 2 of them to controller 2 RGB hubs of 6 fans each ..
https://www.corsair.com/uk/en/Categories/Products/Accessories-|-Parts/PC-Components/Cooling-And-Corsair-Link/CORSAIR-RGB-Fan-LED-Hub/p/CO-8950020
But then buying 6 single fans and two bundle packets is cheaper then 4 bundle bundles , and works out the same with including the Command Pro
4 packs and fan PWM splitters Vs
My basket at Overclockers UK:
- 4 x EK Water Blocks EK-Cable Y-Splitter 3-Fan PWM (10cm)= £2.99
- 4 x Corsair LL120 RGB, 120mm Dual Light Loop RGB LED PWM Fan, 3 Fan Pack with Lighting Node PRO= £89.99
Total: £382.42 (includes shipping: £10.50)
2 packs + 6 fans + splitters
- 2 x Corsair LL120 RGB, 120mm Dual Light Loop RGB LED PWM Fan, 3 Fan Pack with Lighting Node PRO= £89.99
- 6 x Corsair LL120 RGB, 120mm Dual Light Loop RGB LED PWM Fan= £24.95
Total: £354.24 (includes shipping: £12.60)
Vs
Command Pro + 2 packs + 6 fans + 4 splitters ( set of 3 fans ran from board )
- 1 x EK Water Blocks EK-Cable Y-Splitter 3-Fan PWM (10cm)= £2.99
- 2 x EK Water Blocks EK-Cable Y-Splitter 2-Fan PWM (10cm)= £2.99
- 1 x Corsair Commander PRO RGB LED Controller + Fan Hub - Black= £64.99
Total: £416.24 (includes shipping: £12.60)
I believe command unit gives better fan control over Asus mobo, best mobo I've used for fans is gigabyte but even still not as good as units such as the Command pro
