Permabanned
- 23 Jan 2006
- Up a Tree...
Graphics card runs max speed / NO Display.... help!
hello.
well i just got my new psu. Corsair HX 620W
since my old HIPER died..so..
my pc now works yey!.... but...
my problems are..
1st - My graphics card is running at full speed when i turn on the pc. and it will not slow down, like it should after few seconds on boot.
2nd- also my graphics card ATI 1900XTX saphire 512mb, is connected to my dell 2047 monitor. using the DVI cable, but when the pc is on. it just turns the monitor to sleep, i dont get a picture of nothing, when i pull the cable out, then i see no signal... but its all connected... i just dont see anything.
3rd- my XFI - Fata1ity sound card 64mb, has a RED light on the site. im not sure if that means power.. or just for fancy, but it has power going to it. i just never noticed it before?
can anyone help me in this situtation?
im still stuck, and dont want to leave the pc running for long. if my graphics card is spinning at max, and there is no picture on the monitor...
i have got my xbox in the other leave.. the AVI one.
and that works fine, i just switch it over, and lights up...
what is causing it? i checked all cables, and it seems ok...
any thoughts?
thanks for your time.
cheers
hello.
my problems are..
any thoughts?
cheers
