Caporegime
- 9 Nov 2009
- Planet Earth
You do not need frametimes it will not stutter as long as it hits the minimum 60fps. I have never heard of a cpu that has stutter. I would imagine it would be called defective for gaming and i have owned budget chips before and played games on them from the 2500M to E6300.
Putting it in a benchmark with a 290x or something is just wrong lol. The same can be said of running it in a game that clearly uses above 2-3 cores like Battleturd series. Although for the money i mentioned for possible 4.8 2400mhz DDR3 and a 270X OC at £600 what could compete? You could probably buy a lone 4790k 2400mhz Z97 rig and use the IGP 5000/6000 or whatever they use now but from what i can find they do quite bad at Skrym,wow,Bioshock compared to the £113 270X OC.
I have owned plenty of CPUs/played on systems with everything from an E4300,recent Core i3s,APUs, FX6300s and Core i5, Stuttering has to do with frametimes,which is not something you can ignore. Thief does show stuttering on dual core CPUs,ie,there are large noticeable spikes in frametimes when running the game.
Also,having high framerates does not mean smooth gameplay - we saw that issue with Crossfire around 2 years ago in a number of games. We even saw it with some games like Skyrim in single card setups.
Look at the TH review again - the Core i3 beats an overclocked G3258 in most games. If games are that lightly threaded,HT should have no effect at all.
The problem is that the Core i3 used to be a £100 CPU,now it can be had for closer to £70 to £75,and even Core i5 CPUs are breaking the £130 barrier!!
Why do you think no Core i3 K was released??
You can easily do a Core i3 and R9 270 based build for £600 since I have done such builds before. It will be far more balanced than that Pentium dual core,especially considering the way games are going. The Pentium dual core has its uses,especially for games like WoT,just like an overclocked E8400 or E5300 did too. Yet,the Q6600 at nearly £100 outlived both of them.
Plus you are not guaranteed upper end overclocks. One batch might do 4.8GHZ on average and another 4.4GHZ,another 5GHZ,etc. The maximum overclocks argument has never worked for any CPU whether it is Intel or AMD. The same goes with GPUs too. I had a rubbish Q6600,a fantastic E4300,great HD5850 and a crap GTX660. Same with some mates - one had a great Core i5 3570K,rubbish HD5850,great HD7870,crap HD7850, a rubbish Core i5 2500K, another had a great FX6300(could hit 4.5GHZ easily) and another a crap FX6300(needed much voltage to even hit 4.4GHZ) and so on(lost count).
You always see people saying you will get XYZ massive overclock guaranteed and when some person gets a crap overclock,it usually ends up with people saying you need to spend XYZ more and so on.
What games would you say need to be tested Cat?
As i'll being doing just that, with a single 290. Overclocked the GPU to try and bottleneck the CPUs as much as i can
I've got a few games, just takes a while to download the larger ones
Backed a lot of them up, just need to find the drive they're sitting on![]()
What list of games do you have??
Do you play PS2 at all??
Would be interested to see how PS2 runs on it TBH. Might be quite good for it.
Just own them.
