- 23 Jan 2018
- Coventry UK
What are people opinion on this monitor?
Do you own one? what are the pros and cons?
I only just received mine and have only used it for a few hours so am still playing around trying all the settingsWhat are people opinion on this monitor?
I pulled the trigger on Jeffs offer as well in the end. same boat as youI only just received mine and have only used it for a few hours so am still playing around trying all the settings
Am trying to think of a way so i can set up my older IPS PG348Q next to it so i can compare them, But that not an easy thing to do as my desk is only just big enough for a single monitor..
what monitor are you upgrading from ?I pulled the trigger on Jeffs offer as well in the end. same boat as you
Pg348q as well. How have u been getting on. Mines do between 2-3pmwhat monitor are you upgrading from ?
I ran the shadow of the tomb raider benchmark in a fairly dark room with HDR enabled and wow it looks dam amazingPg348q as well. How have u been getting on. Mines do between 2-3pm
Did you receive yours today ?Mines do between 2-3pm
I know what you mean by it not plug and playIt’s an absolutely fantastic monitor, won’t regret it. I got it 4 weeks ago (upgraded from a PG279Q) and the only thing that needs is to fiddle a bit with calibration and settings, it’s not just plug and play as my previous one was. Definitely worth it and in a league of its own (yes pricey but well worth it), should serve well for a few years.
Balls didn’t even know they did one. O wellAOC version is half-price atm;
https://www.overclockers.co.uk/aoc-...rved-widescreen-gaming-monitor-mo-04z-ao.html
Is that what you’ve turned yours down too?I know what you mean by it not plug and play
Last night i workout there this HDR/SDR brightness balance slider in the windows settings that you can adjust so you no need to keep switching the HDR mode off & on
Yes i moved the slider down to number 10 and it still a bit too brightIs that what you’ve turned yours down too?
)Does make me wonder if there a new version of these monitors coming out with a few updates like HDMI 2.1AOC version is half-price atm;
Last night i worked out that there this HDR/SDR brightness balance slider in the windows settings that you can adjust so you no need to keep switching the HDR mode off & on
How you getting on with it ?Yes mate. Over the moon with it. Games look so awesome. Still got loads to look at in settings
