- 12 Sep 2017
After all the advise that we have given you, you still try and cheap out on the PSU, i mean how do you know that unit has not been running on a mining rig for the last 3 years 24/7?? There are ways you can cut costs when it comes to building PC's, but PSU's are not one of them!!
I feel at this stage i would make more progress by banging my head against a wall.
@markymoo I think you should upgrade it, especially if you are thinking of upgrading other components. The Antec unit i posted above is a cracking unit at a reasonable price with a 7 year warranty.
Please remember, manufacturers dont create all of their PSU's equally, if you look at the PSU Tier List i posted above, Antec have units in 6 of the 7 tiers, always aim for tier 1 or 2, tier 3 if your on a tight budget and dont have top of the range parts.
I appreciate all the advise given to me, I really tried to get the best setup I could afford, my father in law is a fully licensed radio amateur and knows a lot about psu, s and has replaced capacitors in loads of them, he is going to test the psu out before I put it in my pc and check the capacitors etc. I also emailed the guy before I bought it and he said it's hardly been used much and was bought end of 2011..
Im not saying I will keep this forever but at least want it to last me a couple of months. Like I say tho I really appreciate everything everyone has said but I just could not afford to buy a brand new psu, so I went with a decent quality 2nd hand one in the mean time
