Notorious Lee said:Now my machine keeps turning itself off I am now concerned the cpu is damaged as 86 degrees is hot.
Notorious Lee said:Also, I am now thinking of buying a new heatsink & fan tomorrow & fitting that?
Dingleberry88 said:TAT doesn't work with nForce motherboards. CoreTemp does though.![]()
OP: make sure you manually set the voltages in the BIOS. Leaving them on auto gives you more than you need.
