If you're using a different router and switch and still getting the same issue, then it's highly unlikely to be either of those, back to the common elements here (cables) and the source PC, but you changed boards, so that wouldn't normally carry over.LOL i'll gladly pay for mine!
Well i've been using Amazon as my 'test kit bin' LOL So i can still try what you are saying, So my brother and i have 2.5gb Lan port PC's so we could set them with Static IP's, i assume iperf is an app. It will be a couple weeks till the TP-Link Archer BE9300 arrives so i have switched back to the EE Smart Hub Plus that they supply with the 1.6gbps FTTP package, which has a 2.5gb WAN port to connect to the Nokia ONT with a 2.5gb port. but all the LAN ports are 1gb, however i have connected the Zyxel 8 x 2.5gb and was instantly getting drop outs with in 15-20mins. So that one is out the window, the TP-Link MG 108 something its called also a 8 x 2.5gb also giving drop outs! So those have gone back....so far the QNAP 2x 10gb and 4 x 2.5gb is holing up the best with only 2-3 drop outs in 12hrs or so.
So i'm switching my PC to 1GB FUll duplex mode and testing that.....if that fixes the issue.....what does that mean? i mean im trying to get a 2.5gb network going, so running in 1gb kind of defeats the object of it all LOL
Iperf is a command line tool that can be used to do simple performance between devices and a lot more, I use it on linux/BSD, but windows binaries are available https://iperf.fr/iperf-download.php
Helpfully MSI just list Intel 2.5Gb/s LAN in specifications which is pretty poor. The i225 rev a and b were a cluster duck of stupidity, intel actually reclassified the rev a as gigabit only at one point as they couldn't fix it in software, but rev c. onwards (I think we were supposed to be getting a rev. d) was OK, and then we moved to i226. Could this be using an i225? Possibly, but I wouldn't have thought so, let alone an early i225 as the issue was well known and documented way before the MSI Tomahawk Z790 was a thing.Just came across this
Network Issues with Intel® Ethernet Controller I225-V
Recommendation to update Non-Volatile Memory (NVM)www.intel.com
, but its been fine for the past 4yrs :shrug:
