- 26 Sep 2013
- West End, Southampton
Show us videos dragonal not text hype.
"Did a test of DirectX 11 vs. DirectX 12 on an unreleased GPU with an 8core CPU. DX11: 13fps, DX12: 120fps. Lighting and lens effects."
crossfire on a as far unreleased GPU.
Fiji
The card to be worthy for
Thanks AMD for Mantle
I do also hope the r9 380 does have... will have pretty high power consumption too.
http://wccftech.com/amds-fiji-gpu-c...-lineup-rest-cards-feature-current-gcn-cores/
I really hope the r9 370x is not just a rebadged r9 285 and actually has the full 2048 shaders at least otherwise the sub £200 market is going to stagnate for another year.
I do also hope the r9 380 does have improved power consumption over the r9 290 via firmware and hardware changes.
A bigger question is whether the rebadged parts will be fully dx12 enabled.
Well this is misinformation, AMD have said no such thing, it was Oxide Games who said this.
They are trying to pin it on AMD so people rage when it's nothing. Wouldn't be surprised if NV pays people in the press and elsewhere to do this.
I hope if it does have improved power consumption that it doesn't gimp the card like the 970. The 290x only draws on average 60/70 watts more than a 970 so I'd sooner have that than low usage/fps problems.
it'll be the same high power consumption, noise and heat as the 290X, dont forget that it's a Rebrand
basically they're selling off the 290X real cheap right now, rebranding the remaining stock that they cant sell and upping the price again in a months timein the firm knowledge that their fanboys will still buy it, you have to ask yourself this......are AMD smart or GRAPHICS CARD fanboys Dumb ??
I meant the R9 290 rebadge - not the SKU above it.Very unlikely
If it is the flagship card it will have rough the same power consumption.
When GM200 finally shows up it will have pretty high power consumption too.
basically they're selling off the 290X real cheap right now, rebranding the remaining stock that they cant sell and upping the price again in a months timein the firm knowledge that their fanboys will still buy it, you have to ask yourself this......are AMD smart or their fanboys Dumb ??
It won't be a rebrand as it does not take about 8 months to do that.
What are you running the cpu at now, because tbh even at stock i havent found a 4790k to hold back a pair of 780's, 970 sli isnt that much difference from them. I do still run at 4.7ghz daily, but even thats overkill.Yes, but to replace my cards i feel that it has to be something pretty special and one card only..
then i can increase my PCs overclock to what it once was............because it had to be reduced due to SLI........... 2 months later
