Haven't you heard AMD will be out of business by then and poor old Matt will be looking for a new job.![]()
If they don't have a good 2015, that's more likely than ever.
Well yeah, it just depends when the user counts as the"start". Funnily nvidia users count nvidia releases amd and count amd.To be fair to them wasn't the 7970 out about a year before the nvidia released a card to go head to head?
Before that I remember I had an x1900xtx for ages before the 7900gtx came out.
Just saying. It's not always AMD that are slow off the mark.
Question is, although of course only speculation would some of us need to upgrade our PC"s to take full advantage of crossfire 390x or dual cards? at one time i was researching getting the dual 295x dual cards, lots of reports that 3 way with an existing 290x would be bottle necking chips like 2700k, With the sort of demand a dual 395x will be demanding more than the 3 way 290x?
yes i think so, i had the i5 2500k with the 7990 and it was ok.
BUT a 390X Crossfire will be a massive increase, so i would deffo upgrade an older rig for these cards....but i guess it depends on your mobo and RAM as well
a 395X2 will be the same power consumption as a 295X2 which also equals a 7990 as well, roughly............BUT a 3 way 290X overclocked will be the most, but the big problem here is the inability to provide adequate ventilation to the front top fans !!!!
you will deffo need to look at your PC case
means that if you have two 4GB GPUs you will in fact get 8GB of usable graphics memory instead of just 4GB like you do right now. This is because instead of tasking each GPU with rendering a whole frame on its own, each GPU would actually render different parts of the same frame
Read more: http://wccftech.com/dx12-nvidia-amd-asynchronous-multigpu/#ixzz3SlFc2ulT
A lot of us will still be on sandybridge, i dont think overheating will be much issue, cause we all are expecting them to be hot, and more than not will look for the dual card version of the 390x rather than single card configurations. what ever way round like you say the old faithful 2500k and even the 2700k, might not be enough for this in 395x type card. Of course they will be fine for single card 390x though
I've been waiting since October for the 3xx series but last night I finally caved in and bought a B grade EVGA GTX 970 for £230.
I'd much prefer to support AMD but I ended up losing patience. I'm sure I'm not the only one who's done that in the last few months!
