AMD Radeon R9 390X
GPU Name: Fiji
GPU Variant: Fiji XT
Process Size: 28 nm
Shading Units: 4096
TMUs: 256
ROPs: 128
Compute Units: 64
Pixel Rate: 128 GPixel/s
Texture Rate: 256 GTexel/s
Floating-point performance: 8,192 GFLOPS
Memory Size: 4096 MB
Memory Type: HBM
Memory Bus: 4096 bit
Bandwidth: 640 GB/s
http://www.techpowerup.com/gpudb/2633/radeon-r9-390x.html
AMD Radeon R9 380X
GPU Name: Grenada
GPU Variant: Grenada XT
Process Size: 28 nm
Transistors: 6,200 million
Die Size: 438 mm²
Memory Type: GDDR5
Memory Bus: 512 bit
Bandwidth: 320 GB/s
TDP: 290W
GPU Clock: 1000 MHz
Memory Clock: 1250MHz 5000MHz effective
Shading Units: 2816
TMUs: 176
ROPs: 64
Compute Units: 44
Pixel Rate: 64.0 GPixel/s
Texture Rate: 176 GTexel/s
Floating-point performance: 5,632 GFLOPS
http://www.techpowerup.com/gpudb/2663/radeon-r9-380x.html
AMD Radeon R9 380
GPU Name: Grenada
GPU Variant: Grenada PRO
Process Size: 28 nm
Die Size: 438 mm²
Memory Type: GDDR5
Memory Bus: 512 bit
Bandwidth: 320 GB/s
TDP: 275W
GPU Clock: 1000 MHz
Shading Units: 2560
TMUs: 160
ROPs: 64
Compute Units: 40
Texture Rate: 160 GTexel/s
Floating-point performance: 5,120 GFLOPS
http://www.techpowerup.com/gpudb/2664/radeon-r9-380.html
AMD Radeon R9 370X
GPU Name: Trinidad
GPU Variant: Trinidad XT
Process Size: 28 nm
Memory Size: 2048 MB
Memory Type: GDDR5
Memory Bus: 256 bit
Bandwidth: 176 GB/s
GPU Clock: 918 MHz
Memory Clock: 1375MHz 5500MHz effective
Shading Units: 2048
TMUs: 128
ROPs: 32
Compute Units: 32
Pixel Rate: 29.4 GPixel/s
Texture Rate: 118 GTexel/s
Floating-point performance: 3,760 GFLOPS
http://www.techpowerup.com/gpudb/2662/radeon-r9-370x.html
AMD Radeon R9 370
GPU Name: Trinidad
GPU Variant: Trinidad PRO
Process Size: 28 nm
Memory Type: GDDR5
Memory Bus: 256 bit
Bandwidth: 176 GB/s
GPU Clock: 918 MHz
Memory Clock: 1375 MHz 5500 MHz effective
Shading Units: 1792
TMUs: 112
ROPs: 32
Compute Units: 28
Texture Rate: 103 GTexel/s
Floating-point performance: 3,290 GFLOPS
http://www.techpowerup.com/gpudb/2645/radeon-r9-370.html
AMD Radeon R7 350X
GPU Name: Tobago
GPU Variant: Tobago XT
Process Size: 28 nm
Transistors: 2,080 million
Die Size: 160 mm²
Memory Size: 1024 MB
Memory Type: GDDR5
Memory Bus: 128 bit
Bandwidth: 104 GB/s
TDP: 85 W
GPU Clock: 1100 MHz
Memory Clock: 1625 MHz 6500 MHz effective
Shading Units: 896
TMUs: 56
ROPs: 16
Compute Units: 14
Pixel Rate: 17.6 GPixel/s
Texture Rate: 61.6 GTexel/s
Floating-point performance: 1,971 GFLOPS
http://www.techpowerup.com/gpudb/2661/radeon-r7-350x.html
