Caporegime
- 18 Oct 2002
minimum range? from my understanding Freesync works between 9Hz and 240Hz! Correct me if im wrong. If the monitor doesn't do that range its the monitor not freesync.
I am loving 28nm![]()
Yeah but you're nutso![]()
Could be worse, we could be poor console peasants.....![]()
You realise that below a threshold sending the last minimum frame that is stored if the screen hasn't refreshed in time is.... v-sync.... right. G-sync doesn't kick in below minimum refresh, g-sync defaults to v-sync above the max refresh rate and an effectively v-sync mode below the minimum refresh rate. v-sync being just sending frames in the frame buffer(something all cards have had for as long as you can think of) if the new frame isn't ready. If you're acting like that is some kind of g-sync magic you're nuts.
Gaming at lower frame rates, sub 30fps, sucks, it's that simple, smoothness from the screen is one thing, smoothness from the actual gameplay is another entirely. For donkeys years we've had so many people laughing at the console peasants on this forum for gaming at 30fps, laughing at the "you can't see above 30fps" arguments. Now all of a sudden gaming below 30-40fps is brilliant because it's slightly smoother? It still doesn't actually introduce the fluidity that is seeing 60+ frames. Spinning around in an fps, every turn is divided into less images. As with motion blur where there is more than one type, there is more than one type of stutter.
I've said since day one, the only place anyone should want any kind of sync to work is in a 50-100fps range, it should provide small boosts to smoothness without tearing in that range. You don't want to be playing at low fps regardless of sync and above 90-100fps you should be using low motion blur modes anyway.
I don't know anyone, literally anyone who gamed on a 120hz screen and said they couldn't see the difference. 95% of people on here are like "I didn't think it would make such a difference but I'm blown away, I'll never go back". Yet you have the *sync guys saying, whoa, lets run our screens at 25fps and 50hz.... awesome... no thanks. DIminishing returns means say 70hz, a small increase over 60hz, is a much bigger difference than 120hz is from 110hz. So I'd be willing to sacrifice some fps and play in that range in between 60-144hz but I have zero interest in gaming below 60hz. None at all. In games where I have crappy frame rate(the only ones I can name or TWIMTBP/Ubisoft games) I'll take 120-144hz and v-sync, or no v-sync, for the majority of games where it's easy to get 70+ fps, currently I run 120hz, on my next screen maybe I'll run freesync, maybe I'll run 144hz, I really don't know.
Agreed, as long as we have the good stuff too![]()
I don't know if you've tried GSync for any amount of time DM but I've been playing alien isolation at 4k with a single 780, it drops into the high twenties at times and is still perfectly playable. To me the difference is stunning.
yer its http://www.overclockers.co.uk/showproduct.php?prodid=GX-167-PC out of stock with no ETA and they told me powercolor could not fix or replace so im assuming there not making anymore
From another thread
Seems that Powercolour are out of stock for the PCS+ 290 and they can't fix or replace so I would guess the other AIB partners are also going to start getting out of stock ?
Does this seem an imminent release of the R9-3XX series ?![]()
NO...........we wont get the 390X till june.....FACT
but they need to release some marketing very soon, because this is so damned annoying now
When Mal says it's fact it is infact FACT![]()
AMD have stopped shipping chips a while back I think.
How can they go through April and May with nothing to sell though...
If you said it's a fact, I guess it is
The problem is more about the 3 month gap of no high-end AMD cards in stock IMO. (don't know the stock available from other AIBs, but I guess everyone is clearing house as fast as possible)
