- 14 Jul 2005
- Birmingham
Thanks but if I'm thinking whether to justify spending 200 I ain't going to be considering spending nearly 500.
Cheapest option would be a thermal camera module to hook up to a raspberry pi or Arduino etc (but unless you already have a pi then there's the cost of that)Thanks but if I'm thinking whether to justify spending 200 I ain't going to be considering spending nearly 500.
Those are depressingly low resolution though, 8x8 at 10Hz. The mobile Flir was bad enough really!Cheapest option would be a thermal camera module to hook up to a raspberry pi or Arduino etc (but unless you already have a pi then there's the cost of that)
Adafruit AMG8833 IR Thermal Camera Breakout (STEMMA QT)
Add heat-vision to your project and with an Adafruit AMG8833 Grid-EYE Breakout! This sensor from Panasonic is an 8x8 array of IR thermal sensors. When connected to your microcontroller (or raspberry Pi) it will return an array of 64 individual infrared temperature readings over I2C. It's like...thepihut.com
Yep wouldn't be a great option, but it's the cheapest option I know of.Those are depressingly low resolution though, 8x8 at 10Hz. The mobile Flir was bad enough really!
. I can't justify £200 on something of limited functionality and bound to be obsolete in a few years but I can justify £500 on something that is functionally better and will last a lot longer.
I have the Topdon TC001, currently available for just over £200 on Amazon. Resolution is better than the Flir equivalent. There is also a Hikmicro, same resolution but £169.Thanks but if I'm thinking whether to justify spending 200 I ain't going to be considering spending nearly 500.
They look very well used, but the pilot hole drill bit still looks sharp.I have just come across these in a box and at first didn't know what they were but after googling they seem to be some of the first hex holders.
These are Dewalt and as you can see one is for pilot holes and the other took the bit.
They do come up on Dewalt but no prices so think they have been obsolete for a number of year's - Been trying to clean them with those cleaning wipes. They were yellow originally but do not look as bad as picture shows.
bought myself a milwaukee 12 ah high output battery on a black friday sale to add to my 8 ah HO battery. They are damn expensive.
It mainly for the chainsaw I bought earlier this year, although I'm also thinking of buying the quik-lok gardening tools (strimmer, hedge cutter, etc.) and it will be good for those too.
Great man mathsI saw a demo of the PowerStack batteries yesterday.
I want.
The increase in power output for your average power tool was simply amazing.
The problem is that the damn things are so expensive. It's really difficult to justify the cost.
I'm tempted in to buying a new router just because it happens to come with two of them, lol.
There’s a lot of 512 wrench’s for half price too on eBay. Fake ?
