- 31 Jan 2022
- UK
Went to use my Bosch blue drill driver this week and the 18v battery was proper dead. Could not even get a LED illuminated on the charge level test function and battery would not charge. Was about to bite the bullet and buy a new one but fortunately did some Googling and found out about jumping the battery!
Connected it directly to one of my DeWalt 18v batteries which had charge (+ to +, - to -) and was able to do a charge level test on the busted Bosch! Disconnected after 15 seconds and then put in charger, started charging immediately and has been successfully resurrected!
Never heard of that fix. But then I never had a battery fail, apart from explosively. I once made the mistake of buying some cheap Chinese batteries that caught fire when charging.
DeWalt batteries they have always "faded" just slowly holding less and less charge until useless. Can't say I ever tried to resurrect them.
Interestingly, where do you all store your batteries? It just occurred to me that I store them in a plastic container in a wooden workshop! Maybe I need to buy a steel cabinet.
