Is this http://www.homebase.co.uk/en/homebaseuk/worx-wx368-18v-li-hammer-drill---2-battery-172456 worth it with a 3 year warranty?
It's a 3rd of the price of http://www.diy.com/nav/fix/power-to...rdless-Combi-Drill-XR-13008707?skuId=13519410
I know its going against the mentioned makes but we are talking very light DIY use
It'll be fine for light DIY. No point buying a light trade/industrial tool if it's just going to be putting up a couple of shelves.
The drill and drive speeds are fairly low, but it has decent enough torque as a result. Seems to have some good customer reviews on Argos and is £80 on there.
Speed 0-350rpm/0-1300rpm.
3 to 5 hours charging time.
Maximum torque 50Nm.
Drill weight 2.1kg.
The Dewalt you linked will take far more abuse, has faster drill and drive speed (600rpm/2000rpm), weighs less (1.6 kg), has faster charge time (30 mins), more torque (60nm), smaller size to get into tight spaces. It's a really good drill for the money imo, but it's overkill for a few odd jobs around the house.
