Buy another drill - I have two hammer and one drill driver and it's very handy having a drill in the house as well as garage - I got mine because they were ridiculously cheap when Homebase sold out to the Aussie group.
Probably the better option to be honest.
I have a Bosch green at home but usually use my cheapo one instead. Same at work, we have a Bosch but everyone reaches for the budget one first.
It's not that the Bosch is bad, it just has a "safety feature" which is actually more of an annoyance than anything. If it senses it is overheating due to restricted airflow, it cuts off the heat. Now whilst this sounds good, if you happen to hold it just slightly too close to the surface you are heating the heat cuts off and you have to wait for it to cool down fully, reset itself, then heat back up again.
Can anyone recomend an oscilating multitool. Only likely to be used now and again, so doesn't need anything too expensive.
Ryobi 18v stuff seems pretty good so far. I picked up a brushless combi drill with two 5AH batteries, charger and a bag for £180 in B&Q earlier this month.
Not bad since the batteries are £90 each without a charger and the drill is £100+ separately.
Yes, i've always been surprised at the cost of Ryobi batteries/chargers.
How much are you thinking of spending?
Also, as a note. I've bought a few "Flagpower" Dewalt batteries from Amazon and they've been excellent at half the price of the real thing, i believe they do Ryobi versions too.
As an update on my Dewalt leafblower. I bought it for £170, sold the 5AH battery and charger for £60, and then this morning sold the DCD796 drill that was free due to a Dewalt promotion for £70 so the leaf blower actually only cost £40 compared to £150 that the bare tool goes for.
Bit of hassle but really pleased with that
I was looking at the brushless 18v drill, impact driver, 2 batteries for £170 in Homebase, although the website currently says £300
To be honest I didn't look at it this way, you are right.I wouldn't be without an impact for driving screws.
Especially when you need to drill a pilot hole then screw. Much faster if you have two tools.
You won't go wrong with any of the 3 above.
5ah batteries are probably overkill for home use.
I prefer the lighter weight 2ah batteries for home.
If you holding them above your head or in awquard positions lighter weight is more important than power.
5ah is only really needed for saws or sds IMHO
