Borrowing my neighbours corded drill for the 4th time or something so thinking it's time to buy my own decent drill. I've got an 18V cordless which is fine for bits and bobs but probably time to buy something with some grunt.
I can see you can either spend about £60 and get something like this
https://www.wickes.co.uk/Wickes-SDS+-Corded-Rotary-Hammer-Drill---1500W/p/141156
or spend roughly double and get something with a brand name
https://www.wickes.co.uk/Makita-HR2630-2-SDS+-Rotary-Corded-Hammer-Drill---800W/p/169583
If I had a big DIY project coming up or planned to ever take on a huge project I'd get the latter for sure.
Just wondering what difference in quality and longevity there might be between the two, e.g. is the latter made up of much superior parts and will last 20 years whereas the first will be more like 10? Or would I just be paying more for the brand name?
Basically looking for a reason to justify the more expensive one even though I don't have a need right now!
The makita is also only 800W compared to the 1500W wickes model. I guess 800W should be plenty though?
