On the Ava models that blow fuses, apparently a workaround is to press the trigger in and hold it when you switch the machine on.
I'm also looking at pressure washers and the Direct Hoses OR11 has good specs for the money, 660ltrs per hour and 2,100 PSI / 145 bar pressure.
You can get the car and home pack (comes with different nozzles, a surface cleaner, foam lance and drain unblocked) for £335. They're easily serviceable too, but I have to admit, I've read some unsavoury ratings online about after service.
Today I sent an email asking if the pump is fully metal, they specifically state on the Grey 7 and Grey 10 product pages that the pumps are fully metal but not on the OR11. I've not received a reply which I don't think is a great start considering it's a relatively straightforward question. I understand it might be a small setup and could be busy prepping orders received over the Christmas break - but still...
