Got a Nilfisk Core 140 on a good deal delivered today, and was wondering if anyone had any recommendations for a good garden hose?
I have some cheapo no-name that we got 5 years ago, which leaks from both the tap connector and the spraygun (and is too short), so wanted to get something new, longer, and better suited to supplying a pressure washer.
Yep. You're wrongI'm prepared to be wrong on this, but IMO a hose is a hose. The connectors are easily replaced with something better if they're leaking, which they all will eventually. Just avoid Hozelock.
About the hose anyway. The hose dave28 recommends (for example) is far less likely to kink than the cheap garbage that you get in a supermarket or even B&Q. Hozelock aren't too bad but their prices are ridiculous. Their anti kink hose does kink too... Good hose connectors to buy are those you find in the home and garden aisle of Asda believe it or not. Cheap and solid - buy two or three for spares and it's still less than a single Hozelock connectorGot 30m of TW Wholesale on special, hooked everything up and it fed my pressure washer like a champ, thanks.FITT 50M HEAVY BRAIDED NTS WINTECH HOSE
I find these types of hoses are very tight fitting so I use boiling water to soften them before fitting
TW Wholesale hose pipes are also quite good but they seem to have put prices up. Im sure they used to be much cheaper last time i bought one.
Sodium Hypochlorite is the base chemical which is used to make bleach. Bleach is generally just diluted Sodium Hypochlorite. It's a thoroughly nasty product and you have to be very careful where you pour it. It is an effective cleanser though as it basically just kills everything that comes into contact with it!It's basically a bleach like product.
yeah, that time a couple of months back I was spraying it on with a new back-pack type sprayer that i'd just bought. After about an hr, I noticed that my back was sore and just blamed it on the new backpack sprayer rubbing me the wrong way. It was only after another while that I realised I hadn't tightened the hoses completely tight when putting together the new sprayer, and under pressure it was driping out of the top of the backpack, and down my neckline. bleached out my pullover, tshirt and give me a couple of annoying burn marks on my back. Luckily the clothing took the brunt of it, but back was pretty annoyed for several days.Sodium Hypochlorite is the base chemical which is used to make bleach. Bleach is generally just diluted Sodium Hypochlorite. It's a thoroughly nasty product and you have to be very careful where you pour it. It is an effective cleanser though as it basically just kills everything that comes into contact with it!
You use the same creams for bleach burns as you would scalding type burns
I tend to go OTT when I use it for the paving, elbow length chemical gloves, safety goggles, mask, and old wax style waterproofs + wellies lol looks ridiculous.
