Nothing in the past number of pages that’s helping?What pressure washers are people recommending?
On mine, I can twist it to lower the pressure. Does yours not do that ?Anyone replaced the nozzle on a nilfisk for a more car friendly one? The standard ones are quite powerful.
My “Gentle” nozzle with my Core 150 is adjustable to focus or widen the water jet. On power setting 1 it’s very soft.On mine, I can twist it to lower the pressure. Does yours not do that ?
Yep, I bought the Nilfisk "Auto" nozzle when I bought my C110 (8 years ago!)Anyone replaced the nozzle on a nilfisk for a more car friendly one? The standard ones are quite powerful.
have an Ava one that seems pretty good. No issues so far.
Same. I had a K2 where the pump died and released the magic smoke. To be fair to them they did replace it under warranty, but now I've got a Nilfisk C110 and despite them being rated for the same pressure, the difference is night and day. Never going back.gone right off Karchers - everyone i know has had theirs break one way or the other - split hoses, dodgy plastic connectors, leaking connections etc - wouldnt buy one again
A slight increase in budget but look at the Kranzle 1050 range.
Truly a product designed to last a lifetime!
The 1050p can be had for around £500, and the 1050TST with inbuilt hose reel for £700.
Why are you after a new gun?Will post here rather than start a new thread.
I'm trying to get a new gun for my Nilfisk Core 130 and I've note a lot of them say following:
"Nilfisk Alto, C, E & P Series hoses (does not fit Spigot connection)" Is a Core a C series or is anyone able to say if the core uses a spigot connection, embarrassingly or not so, I have zero idea what the type of connection is besides a quick release.
The connectors on both sides of the hose look like this:
