Problem with BitFenix Alchemy 6pin PCI-E extension
Here you go mate heres a pic, sorry about the quality they were taken on my phone
This is the end that will plug into my 5850 (2 oval middle pins)
By craney at 2012-01-25
This is the end that the pci-e plug from my PSU plugs into (1 oval middle pin and 1 square)
My PSU pci-e plug also has 2 oval middle pins it just seems to be the end of the extension cable that the PSU pci-e plug plugs into that has the oval and square middle pin
thanks again matey
You have a odd combo of a Version 1 Male and Version 2 Female. If you are concerned about it ask kul1 if the cable can be exchanged.
Though this will still fit and the contact will be the same. :)
I Have had the same issue with my new Bitfenix cables too.
I have a EVGA GTX 580 SC DS - No issue with this the cable fit fine.
I also have a Asus 580 (the first reference card not the DCU version) this has the oval Female.
I simply got one of those tiny little flat head electric kit screwdrivers and shave a bit off the edge. Can't get a blade in there as the surface is in the centre.
No major issue really. I blame the card! 90% of my GPUs have been the square female. This way V1 &2 cables fit.
@panyan: we do have many shipments to Europe and the stock doesnt get conserved even sometimes... meaning while still older ones are in the warehouse the logistic sends out newer ones...
I fowarded everything internally so they check and make sure there are no mistakes anymore.
Kul1 - I have had what seems to be the same issue, http://forums.overclockers.co.uk/showthread.php?t=18559855. I will fire off an email to your support guys this evening when I get access to my mail, but can you give us an update on this?
Oops - don't use that email address anymore so missed it - email sent - completely missed that you were a rep too :p The photo above shows what I need with the rounded middle pin
I've also got the same problem, I recently upgraded from a 9600GT (cable fit that perfect) to a MSI 290 which the cable doesn't. I also noticed the colour on the 6pin is a faded red compared to the 8pin. Just sent in a webnote...hopefully they can send me out a replacement with the 1000W Superflower PSU I've just bought....
