problem with gpu
4 Nov 2014
so i built my first ever gaming pc
1 x Gigabyte Z97X-UD3H-BK - Devil's Canyon Core i7 4790K CPU & Motherboard Bundle **£30 Saving + Gigabyte Free Upgrade + £30 Intel Cashback ** £372.98
1 x Gigabyte GeForce GTX 970 WindForce OC 4096MB GDDR5 PCI-Express Graphics Card (GV-N970WF3OC-4GD) £263.99
1 x AOC G2460FQ 24" Widescreen 144Hz 1ms Gaming LED Monitor - Gunmetal £158.99
1 x Avexir Golden Blitz 16GB (2x8GB) DDR3 PC3-19200C10 2400MHz Dual Channel Memory Kit (AVD3U24001008G-2BZ1SE) £139.99
1 x Corsair Obsidian 450D High Airflow Mid-Tower Case (CC-9011049-WW) £91.99
1 x Corsair Hydro H110 280mm High Performance Liquid CPU Cooler (CW-9060014-WW) £91.99
1 x SuperFlower Leadex GOLD 850W Fully Modular "80 Plus Gold" Power Supply - Black £89.99
1 x Crucial MX100 256GB SATA 2.5” 7mm SSD + 9.5mm Adapter (CT256MX100SSD1) £79.99
1 x Microsoft Windows 8.1 64-Bit DVD - OEM (WN7-00614) £77.99
1 x Toshiba 2TB 7200RPM SATA 6GB/s 64MB Cache - OEM (DT01ACA200) HDD £57.98
1 x CM Storm Devastator Gaming Bundle - USB Keyboard & Mouse £29.99
the build went well, but i have a problem for some reason my gpu doesnt seem to be recognised by my pc kinda, if i use CAN I RUN IT then it says i have a gtx 970, but if i ask if i can run a game it says i have integrated graphics with only 256mb of vram, ive downloaded all the latest drivers to no luck.
any advice would be appreciated
In the BIOS, I think its a page called integrated peripherals or something like that, you should see it and its probably set to auto, the other options are disabled/enabled.
And both PCI-E cables are in the GPau, from the PSU. Sounds silly but its easy to overlook sometimes. Just ensure all connection a are secure.
Have you tried various GPU outputs? Eg. HMDI, DVI ect.
