Problem with MAXDATA computer
27 Dec 2008
I'm helping a friend who is having some issues with his MAXDATA computer
Spec
1Gb DDR2
350W unbranded
ATI 2600pro 512mb
MOBO, RC410-SB450
when the power is turned on it makes a series of clicking noises and refuses to boot up
it then makes a series of beeps
the graphics card is the problem so i removed it and used on board graphics
this allows to computer to boot up
iv tested the card in my pc and it works fine so am thinking its the pci-e slot or the mother board
any surgestions guys??
yer was thinking a new system, problem of being students we have no money so it might be hard to get one.
no chance of getting a bios update now is there
will check my card in his pc later. if that dosent work the mobo is knackered and il b posting about a low cost pc spec
the card takes its power from the pci e slot does that make a differance??
i think it only has a 20 pin connector didnt see a 12v line when i opened it up
how can i test it under load then??? i have a multi meter which pins do i need to measure it from
and how do i do it with out electicuting myself
Here are some guides:
http://www.devhardware.com/forums/p...a-multimeter-how-to-use-it-to-test-75111.html
http://www.ochardware.com/articles/psuvolt/psuvolt.html
http://www.motherboards.org/articles/guides/1487_1.html
To load the 12V line use utilities which are used to test CPU overclocks such OCCT or IBT.
Make sure that your computer is well cooled though,ie, make sure it is in a cool place with decent ventilation.
You may also want to test the 5V line by using a utility which will stress the hard disk a bit such as Crystal Disc Mark.
Most importantly I would back up any important data beforehand.
