Problem with my 5090
20 Sep 2024
Chile
The two holes in the GPU bracket have rolled away, and I can't insert the screws; they just spin and aren't secure. What's the solution? can i use zip ties to secure the bracket??
Which type or screw should i use to fix this issue?
photo 1
photo 2
I often use screws with nuts/wing nuts on fans rather than self-tappers, but I don't think they'd hold that kind of weight.
does zip ties could work as a temporal solution?
If the card is held securely and supported underneath, probably, but I personally wouldn't want such a heavy/expensive item to be reliant on a plastic zip tie.
I'd rather have the case lay flat (horizontal) than rely on a zip tie.
yeah, i agree ...
Are the holes in the case actually stripped out or is it just an alignment issue?
As for the missing screws themselves, just remove a couple expansion slot covers from below where the card mounts. The screws that are holding the covers in place should also hold the GPU in place. -If you can get an extra set of hands to help get it lined up.
  • Like
Reactions: sg0
I only vertical mount recent heavy GPUs. Becasue I've used many of them I'd use a tool to insert two Rivet Nuts in the existing holes. Bit OTT but then those GPUs are very expensive. Also make sure the other end is supported because a big failure point on 4090/5090 is either the GPU solder balls lifting or the PCB around the PCI-E slot cracks or delaminates.
Slight chance a Rivet Nut will protrude enough to partially block one of the ports so the bolt/nut combo is also a good shout.
That's gonna be really difficult mate, just think a screw with the same width as the original screw but with a finer thread.
I'd have to move a ton of stuff just to access the PC, I just don't have time for that right now.
Or just think of it as a nut and bolt.
It's not a screw and nut, save that for the bedroom :D
I bet he has over tightened and stripped out the threads. People need to go gentle with these screws, finger tight is all that is required. It’s not like working on a car with much larger bolts.
Nut and bolt is the next solution, or get a new case.
yeah, but the threads of the case, not the gpu
Today ive tight the screws on rhe case, without the gpu, and i noticed that
Man, could you give the meassures of the nut and bolt that worked for you?
Mate, I can't get to the back of the machine to do this. Find out the hole diameter, look for a screw and bolt that'll fit through the hole diameter and cut the screw to size. That's it. And use the Internet to see how others have implemented it.
y
Thats ok.
