SkodaMart
SkodaMart
and decided it wasn't worth it.
I kind of saw that one coming!
If he removes one of his graphics cards, that should push his GPU useage nearer to 100% (and its free!!)
Haha thought I might see that image.
My plan all along was to see whether it made any obvious performance increase over my 3570k and the fact that it doesn't, means I can simply return and save my money for something else.
If I hadn't of tried it then I would have been left wondering "was there more performance available to me" when the answer is, no, not with an 3770k.
I am sorry it did not give the performance you were looking for.
This is a pic of GPU usage for mine in sli running BF3 @1600p
http://imageshack.us/photo/my-images/29/membf3.jpg/
I did say as well originally it'll only be a 5% bump at the max over a clocked i5 but it is always worth trying with the DSR there if you're curious![]()
+1
Rusty611 on 3 screens do you get constant high usage or are there any dips like JamesM discribed @1080p
I will admit I am surprised to see that an i5 @ 4.6 GHz is limited in anything, however 670 GTX SLi is some serious rendering power.
It is also interesting to see that the i7 is starting to show some advantages over the i5 in gaming.
What would be interesting is how much difference an overclock makes in a CPU limited game such as BF3.
Overclocked vs stock.
Thought i'd update received the i7 and installed.
First impressions are yes it does make things smoother and yes minimum FPS has increased. After clocking it to 4.6GHz and having a few rounds of BF3 the FPS didn't drop below the 90s so that's an improvement. Also on a plus point the CPU happily ran at 2200Mhz memory and 4.6Ghz only needed 1.3v so was rather impressed with that.
I didn't expect miracles and the GPU usage was still hovering around the 60-95% mark which i'll put down to using 1080p as a resolution.
I've decided i'll still be DSRing the i7 purely because it wasn't a huge jump in performance for the cost.
Only reason to buy it is if you are doing something that will put those 4 extra threads to use.
hi all,
right,
tested both 670's both work fine with single monitor 1920 x 1080 getting 180-250 fps on both
now here is something thats interesting and maybe the issue!!
after testing i put my system back together and now i have no windows boot drive
after further testing looks like my OCZ SSD drive has died, ive check it on both my system and another pc it lights up with red & green light but wont detect in the bios,
OMG am having a bad week![]()
My ocz agility 3 would randomly disappear if i'd been adding/removing other sata drives on my z68 board (asus). Took some fiddling but has worked fine since.
Sounds very odd?
Ahh even though I've requested a RMA I still can't decide what to do. Put the 3570 back in afterwards and it really does struggle with two 670s. It's not a case of the fps just slowing down but the system actually lags/stutters when it hits 30fps which I really can't be doing with.
I don't want to get rid of the 2nd 670 as I will end up with a larger monitor (+resolution) at some point in the future so it will be beneficial. I've got 14 days, i'll see how I get on running it for that bit longer and then hopefully make a decision.
Doesn't help that the 3770k is a better clocker than my 3570 either.
Anyway sorry for taking over the thread but thank you for the advise everyone!
If you've got a good clocker I'd keep it. Bear in mind though that above 4.6 GHz the heat really becomes an issue.
You can recoup £140 easily by selling the i5 I'd say. With that the net cost is around £100 for a slightly smoother experience and HT if any applications you use, use it.
We agree at last!!
