What did you use to cut the motherboard tray?
I used a good ole dremel for the cutting. Works very well, although the mobo tray is very tough, be prepared to use up quite a few blades.
I used black grommets in the holes I cut and square black blowhole trim for the area for the ATX cable.
Is the Sleeving kit enough to sleeve most wires and would you recommend it?
The sleeving kit is easily enough for a full PSU.
I sleeved my entired PSU and all modular cables bar 1 molex and 1 sata power, since I won't be using them.
I'd highly recommend the MDPC-X sleeving, simply the best black sleeving out there.
Would you be able to send me anymore photos of you Sleeving and give me some tips?
The only one I'm a bit nervous about doing is the ATX24 as I'm also going to braid them individually.
I have the sunbeam PSU mod kit but I've heard it's pretty easy to snap the tool when doing the ATX24.
Don't be nervous m8, it's not that hard. Also the sunbeam kit is pretty useless.
I used a good ole staple, just straigthen it then bend it at the middle and you've the perfect tool.
When doing the sleeving, do one or two at a time that way you can avoid getting confused and putting the wires at the wrong places.
Nils is trying to get me black screws for the case too but if he can't what would you recommend I do? Spray them?
I sprayed all my normal silver M3 screws, works really well. Just use very thing coats and leave to dry for an hour between each.
I did the same with my chassis internals.
I hope helps abit, sadly I cannot get any pictures for you yet since I'm back at Uni.
I will try and get some for you this weekend.
Thank you for the compliments, hopefully my last package will arrive within a week or two.
Seems the couriers lost the bloody thing so my entire build is on hold till they send me a new one.
