Now, my holidays have been drawing near, so I really need to get the kit in and see if I like it. Besides, I've been waiting weeks to play Far Cry 3, and now's going to be one of the last opportunities I get!
First I fit the rad to the new hole I've just cut...
Then the res. I'm really not sure about putting it in the drive bays anymore you know. I think I'd like it in the internal drive bay area. Tough - here will do for now...
Then in got the radiators at the top. 3.120 Phobya in the roof with Scythe Jyuni 1900's in the roof, and 1.120 phobya rad at the back. It's a tight fit, but they do go....
Then in goes the CPU block...
My Apogee XT has seen some action over it's life. Still works a charm, even if it is quite restrictive...
Then in go the GPU's...
A bit more plumbing later and the loops complete... At least for test purposes..
Stand back and admire my rushed work...
Functionally, this fulfills my brief - the bitspower fittings to the top and bottom of the gpus are actually quite mobile when in situe - as can be seen from the angle they leave. That'll straighten up once I get the shelf back in and cut the holes in that. I'm going to leave that for now though - this is about getting some gaming time in - and some test folding while I'm off
2 days of leak testing, nipping and tightening later, and I was ready to power up. Don;t think I've ever been so nervous - guess that;s what happens when you've been without your rig for 5 months and can;t afford to replace any parts.
The final pic for today is the test setup:
I installed the SSD, BR write and Soundblaster cards plus front bay, without any issue, then I started the install process. I've been using an evaluation copy of Window 8 on my old laptop (Innova Thinkpad with an SSD in) and I'd gotten quite used to it. Windows 7 just felt weird going back to it.
Whilst downloading all the windows updates and drivers, I spotted my first mistake - for SLI you need to use the 16x lanes and that's slot 1 and 3, not 1 & 2 as I had setup. Thankfully I was able to disconnet my gpus without too much fuss - due to the Koolance QDC fittings, without spilling so much as a drop.
I love it when a plan comes together
All went back together nice before it was time to start overclocking... That's very much work in progress, so I'll leave you with my efforts so far:
http://valid.canardpc.com/2771117
tidy
All with the bios settings still on auto and folding stable so far (2 days of folding, plus gaming on FarCry 3
tidy
