Project - Air Cube v2
OMG Mag feature :D.
The weather is getting cooler now & I updated the temperature reading pic for load & idle, took these print screen pics the other night when my room temp was 20c, to get the clock higher & stable I have to bump the volts quite a bit causing it to use near double power so it will be left at 3.8ghz.
Also bought a second 5870 to do crossfire & the temps are nice & the performance nicer :), only games at 1920x1200 I have to tone down settings for it to run smooth is Metro 2033 & GTA IV (my idea of smooth is a constant 50 fps upwards).
Also got my 1st copy from my subscription of CustomPC today with the Air Cube featured inside woohoo :cool:.
Pretty chuffed :D.
I think up next is a rematch with my first scratch build that was based on the Lian-Li X2000, after that a new original :).
Thanks Tealc & Paul :).
Currently in the design process for my Lian-Li x2000 alike rematch Just doing a few hours here & there & figured a nice simple way to make my own pci/io back expansion piece which I shared the sketchup file on bit-tech, it includes a standard ATX & XL-ATX, it's a simple piece made from 3 layers so no complicated bending needed, just cutting, drilling, tapping with use of countersunk bolts or even sticking together.
Here's a linky for anyone wanting to make one, I believe it's one of those sooo simple ideas that no one thinks of it lol :D.
http://forums.bit-tech.net/showpost.php?p=2431621&postcount=2712
Here is what I have been busy designing over about a month doing bits here & there, then recently finished it up when my internet was bad for nearly a week, vents & other bits will be added when I'm actually making it as my sketchup skills are more limited than my practical skill, but I have the basic structoral form of what I want to make so I have the specs at hand as a good guide.
This was going to be a rematch with my first scratch build & still is but with more flair & a steeper challenge as I attempt to lose the squareness of my cases :D, I know making a square box is easy to me now so if I stuck with square cases there would be minimal challenge for me so wouldn't be learning anything new, don't get me wrong building a perfectly square case is not as easy as some might imagine especially the first time with no previous experience but when you've done it once or twice it gets really straight forward & easy.
Anyway it's going to cost me about £100 more than my last case for aluminium because I'm using a range from 1mm sheet to 4mm sheet & various flat bars & angle bars, I'll need to buy a 12" disc sander so I can make perfect joints & get perfect edges, I've worked out the cost & it's pretty scary compared to my previous cases.
£220 for aluminium with vat & delivery if using sheets :(, but about £80 to £100 if only using bars :).
£50 for plastic with vat & delivery
£30 round about for high tensile bolts & bits.
so £300 or £200 for absolute basics & this is going fully diy.
£50 upto £200 for finishing (paint or powdercoat or anodise or a mix of all 3)
£70 for 10 Enermax UCTB12 T.B.Silence fans or could re-use some I already have but fans keep evolving to be nice & quiet with enough airflow & nice looking which is why I'd prefer to get new ones.
I could do a budget version by using flat bars fixed together which would seriously lower the aluminium cost which I may do + it would be a chunkier case, it'll be interesting to make a case like this purely from flat bars & angle bars while being inspiring to others wanting to make a bada$$ case with a nice small budget, just needs a slight redesign which I'll sketch up before I commit to starting.
So this would be an even higher premium case than anything I've done before, but still cheaper than a top level consumer case, this time when designing I totally disregarded budget & just designed then worked out how much it'll all cost, I did design a water cooled case like this but I just don't like the size it has to be to hold all the water cooling gear not to mention the awkward tubing when it comes to maintenance so I'm skipping water cooling & staying with air for 1 last time ;).
£120 for the sanding disc machine, but this will be a great purchase as I know I'll always have a good use for it, the manual mitre saw I have would go perfect with this.
Met my saving goal so I could go all out on doing this now, but a 32" sharp led 100hz 1080p screen is highly tempting me, but if I got the screen I could sell my 24" led monitor & my 26" samsung monitor putting me close to my budget goal again so I'll probably do that :).
About the design:
All but the rear fan would be mounted independantly to the mobo tray not being screwed into the exterior panels, the bottom storage section will be like an air tunnel, the mobo cooling section will have imediate airflow right next to the mobo & the fan below will give just enough space for the ridiculously long ati 5970 just so it's an option, there will be a fan mounted between the psu & mobo tray & a fan above the mobo tray with a duct to go out the rear, I don't think xl-atx or the like is going to be a new standard so I'm sticking with standard atx, a 10 slot mobo tray is huge & guess it's only applicable to 4x gpu users which I'll never be.
So the only cables that will be slightly visible would be the mobo power cables, sata cable, power switch/led cables & gpu power cables so should look & be really clean on the inside & out.
The hdd tunnel is nice as each hdd cage slides in being held down by flat bars, then a flat bar slots in front of them & they are secured.
The pci expansion piece will involve a chunk of aluminium with pins sticking out to act as a 1 piece lock down for all the pci slots & screwed in from behind.
I'm doing it this way instead of making a new thread because no orders have been made yet so this is fresh off the design stage, then I'll add all this to the first page of the log with some actual progress :), so just think of this as a hazy preview of whats to come next from me.
And now the design pics, any suggestions for a name are welcome, I'm all thought out after designing this for the time being :).
Could be a couple of weeks to a couple of months away before I start.
congratulations on the magazine exposure.
just read through the plans for the next project and liking a lot.
the shape of the case reminds me a bit of that big lianli that was out a while back
Thanks, thanks & thanks Dubs, it's kinda cross between a lian-li x2000 but with different hdd cooling, cross a PC-888 cross my own touches but the PC-888 part was by accident :), Just wish I could start it right now, kinda chomping at the bit :D, shouldn't be too far off before I get started though, I'm hoping any time between a week from now & at the latest january :), depends if I go for the new tv or not.
So in a banzai style which will come first tv or aluminium, place your bets now lol :D.
This is the tv I'm after, heared nothing but good about it & it's full LED backlit unlike most LED screens.
http://www.overclockers.co.uk/showproduct.php?prodid=AV-015-SH&groupid=703&catid=1564&subcat=
Ha, after seeing the screen again I gues I'll start this new project in january :D.
I know where you're coming from re wanting to get started on things. My water-cooling project is nearing an end and already i've got ideas for what I want to do next. Money problems aside, I live in an old cottage that is in dire need of decoration. My good lady in a frank "discussion" we had the other day with regards to the work that needs doing on the house and my apparently misplaced priorities said "It's a shame you can't be so enthusiastic about modding the wallpaper and woodwork". Which left me a bit confused as I didn't think she'd want the dining room black and yellow with UV lighting:D
It's probably best not to tell her i've already got a shopping list together for the next project.
LMAO :D
My Good lady wife gives me funny looks when I start 'fiddling with wires', as she likes to call it. They just don't understand do they.
@waynio - That new case design looks very difficult and imposing. Good luck with it. I will watch that one with interest.
Thanks Tealc, I think I'll leave it til january, it'll give me chance to make absolutely sure the design will work & tweak the design a bit more, just the alu alone is gonna cost more than my previous projects so don't want to be rushing things :) it'll be nice to get everything done right the first time for a change :), besides power tools don't overheat when it's freezing :D, the dremel can go on & on without getting warm, same with any of the power tools I use.
And if I take my time it might be a nice warm spring ready for painting, I got word that 1 of my old mates does anodising too so I'll see if he could do some bits for me, could end up looking like a nice lian-li case if I do it all right, I'd feel better having someone I know handle it rather than posting parts for couriers to possibly mangle them up.
I got that Fractal design R3 case which I'll mod instead for the rest of this year, all it's short of for a full system is an AMD cpu & a cooler so should make a nice little project, I'll class that one as my first sponsored project & the sponsor is bit-tech or CustomPC or Dennis publishing :D, well it's not a sponsor but it's tech I did not have to buy :).
Thank you benhomer737 :), can take ages looking through a long project log eh :D, I go to bit-tech & TBCS & theres just so many crazy cool logs, it would take me forever to look through them all so I just randomly check a couple out now & again.
I sacrifice doing sooo much to support my hobby & with doing so I can save up a bit here & there & when I have a saving goal I want to achieve in a shorter time I sacrifice even more so.
I guess in other words I am very very good at budgeting & scraping by on minimal money.
My next project preview
So, I made the rough design which I already shown & just spent all day rebuilding the design from the ground up (trimming things down & squishing things in basically just readjusting the design for the changes) so it will now have full length panels instead of separate ones & will be a bit more sturdy, also I'm going to do a 2 tone tint that will all fit flush to the alu so will be a heck of a lot more difficult to do but I believe the higher the challenge the more you learn, sure I could get the acrylic pieces laser cut but there's no fun in that :D & it would bump the cost very high, oh & it would be over all too soon :D.
Already ordered the acrylic & the clear acrylic adhesive.
So now it's just a case of saving & raising the cash for the aluminium.
Base panel & motherboard tray is 4mm, 2nd panel, back & sides is 3mm, acrylic is 3mm with a 2mm layer of clear acrylic to properly support the 2 tone flush fit.
I'll be aiming for a whisper quiet case with this by using these fans throughout, they are only 41cfm so are lower than what I'd usually go for but with the orientation of the fans should do the job fine to enable a nice overclock too, they also fit the colours of this build perfectly.
120mm Enermax UCTB12 T.B. Super Silent 11 dBA
http://www.enermax.com/home.php?fn=eng/product_a1_1_1&lv0=4&lv1=32&no=108
Also with me doing windows on both sides I'll be having my first proper go at custom length sleeved cables so it all looks neat on both sides & possibly take a leaf out of Attila's book & make little wire cover boxes to completely hide wires.
The reason there are no vent holes on the curved piece is I have no idea how to do what I want on curved pieces in sketchup, also if you think I've done away with the optical drive I haven't I will make a new bezel for it which will blend with the stripes :).
I might get the aluminium anodised black once all the metal work is done rather than paint it this time, depends if I can get it done at an ok price.
I just hope I don't have too much trouble making the curves as I want them, there will be 3mm aluminium flat bars which should be quite easy to do, originally had it designed for 5mm bars which may have been a nightmare to do right, 3mm acrylic should be very easy considering it will be 3 separate fairly slim strips, the 2mm clear acrylic should be a doddle.
I'll be taking my accuracy to a new level too by getting some digital callipers which I'll need to go along with the disc sanding work.
OK after all this blah blah explanation :D next time I post will be with actual progress on a new thread :), so hopefully this year, if not then early next year, so I'd say either in December or January.
This will probably be my last big project for some time as I'm liking the tiny pc's that are popping up, much cheaper on materials & awesomely small yet powerful & not thirsty for electric, seems the way to go imo but I feel I must whoop my first attempt of a tower pc before I go there :D.
For now though here's a bunch of the revised design pics, say what you think (positive or negative any opinions appreciated) :).
So until I get all the materials I'll just keep cheerleading for other modders lol :D.
I hear it looks rainbow like lol :D can't be having that :p, which prompted me to show it in black :).
Also don't forget the aluminium might be treated to a brush effect with black anodise, I just keep my models in white as it's easier to model.
A couple of alternative panels.
Can't wait to see this mate your one of the very few I enjoy reading going from start to finish keep it up i hope you get the funds soon :D
